Engine Swap Horror
I just bought a 90 civic hatch si with a 97 engine swap. i bought it about a month ago and i cant get it smogged anywhere. i went to state ref. and they told me i need to install a 97 OBDII compliant converter, a 97 PCM, install/replace charcoal canister and check and repair high NOx emissions. Now i don't really know anything about this stuff since I am a new civic owner. I can really use some help on how I find these things cheap and if there is anything I can do to get it to pass without replacing these things. PLEASE HELP!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatRicerDaniel »</TD></TR><TR><TD CLASS="quote">lets be careful guys.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox »</TD></TR><TR><TD CLASS="quote"> i would suggest reading up on 0bd2 conversions.</TD></TR></TABLE>
100% legal
100% legal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_girl04 »</TD></TR><TR><TD CLASS="quote">I just bought a 90 civic hatch si with a 97 engine swap. i bought it about a month ago and i cant get it smogged anywhere. i went to state ref. and they told me i need to install a 97 OBDII compliant converter, a 97 PCM, install/replace charcoal canister and check and repair high NOx emissions. Now i don't really know anything about this stuff since I am a new civic owner. I can really use some help on how I find these things cheap and if there is anything I can do to get it to pass without replacing these things. PLEASE HELP!!</TD></TR></TABLE>
First... what kind of motor?
what does the valve cover on your engine say.... ?....
and FYI... there was no Si hatch in 97 (HERE).... only the 2 door coupe, which was the only Si then. the 92-95 civic SI had a Single Cam.... the 97 was Dual Over Head CAm (DOHC)
can you read the engine code off the block itself? if you don't know where to look it is on the lower left hand side of the block. If you are standing in front of the car look left of where the exhaust manifold is bolted.
sigh i cant belive that u know nothing at all but were willing to buy the car with a swapped motor w/o doing ANY kind of research at all
im a smog tech here in cali not a smog ref, but what u need is to convernt ur wiring to obd2...ur car is runing obd0..i know of no obd0-2 conversions at all?, so if u can somehow get the ecu to work with the car im sure they'll let u go with that, second high nox is due to high combustion temps, i see alot of hondas with high *** nox, things that can raise nox, advanced timing, cooling system not up within specs, build up of carbon in the engine, carbon artifically raise's compression thus rasing combustion temps thus raising nox levels, running to lean will cause nox to go high theres alot of things and u most likely stopped reading after i started explaining things.
sigh u dont know nothing bout cars so u can do a couple things
1. sell the car
2. sell car
3. sell
4. buy a jetta
1. sell the car
2. sell car
3. sell
4. buy a jetta
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">
He knows a lot about cars, what are YOU talking about??? After all, he has a "97' SI Hatch with a single cam w-tech motor".
LOL
LOL
i found two numbers one is engraved on the block and the other is a sticker. the one engraved is D1GY72558366. the one on the sticker is L3-2280650
If it runs right and you don't want to mess with it follow these steps:
1. Take your hatch to nevada on a weekday
2. Go to the post office, get a PO box, have that PO box forward to your real home in santa clara,
3. Get your license there in Navada, Your address is that PO box.
4. Then get your car registered there at the same time.
Believe it or not, this is 100% legal if you insist that you live in Nevada whenever asked
If a cop asks - you live in Nevada, that PO box is an address, how do you think country folk get their mail, the USPS does not drive 40 miles for one house. Any information they need to send you will get to you at your home in Santa Clara provided you forwarded all mail that comes to the PO box.
Cost? It will cost you less to drive there, get lic, get registration, and get po box, than it will to smog your car and register it here in CA. It's cheap there. And if you factor in the money spend on OBD1 or 2 conversion costs that you don't need to keep your car running. You're gettin suckered by California.
OR
Sell your car to me please. PM me your price, i need a new engine. Thanks ~ Nikozai
OR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_girl04 »</TD></TR><TR><TD CLASS="quote">i found two numbers one is engraved on the block and the other is a sticker. the one engraved is D1GY72558366. the one on the sticker is L3-2280650</TD></TR></TABLE>
that did nothing, were looking for a code with 4 letters its stamped on the block of the engine it mite be to dirty, what u gave one is the trans code, the other i dont know
it should start with a Dxxx, or it mite just have 3 if u have a jdm motor Dxx
here are some exmaples of D series motors
D16z6
D16a6
D16y7
D16z6
D16a6
D16y7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX »</TD></TR><TR><TD CLASS="quote">
LOL
i belive its a girl posting
LOL
DUDE!! She gave you the block code... She said G instead of 6... she has a d16y7.
You're going to have to either upgrade your current engine now to OBD2, or trade for/buy an engine called a D16A6 (they're cheap).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede »</TD></TR><TR><TD CLASS="quote">DUDE!! She gave you the block code... She said G instead of 6... she has a d16y7.</TD></TR></TABLE>
DUDE!!!!!!!!!!!!! DUDE!!!!!!!!!!! DUDE!!!!!!!!!!! DUDE!!!!!!!!!
sorry im not Block serial master, like he said u have a d16y7 single cam non vtec motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">DUDE!!!!!!!!!!!!! DUDE!!!!!!!!!!! DUDE!!!!!!!!!!! DUDE!!!!!!!!!
sorry im not Block serial master, like he said u have a d16y7 single cam vtec motor</TD></TR></TABLE>
Wow! It's Ba4's day to make friends and influence people! Grow up and stop jacking it to ebaum.
DUDE!!!!!!!!!!!!!!!!! u wanan keep going back and forth? leave it alone i was just playing with the pic sorry if u took it all bad DUDE!!!!!!!!!!!!!!!!!!!,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">DUDE!!!!!!!!!!!!!!!!! u wanan keep going back and forth? leave it alone </TD></TR></TABLE>
sigh and then your cheerleader b/f had to come in, everyone trying to get there last word we can keep this going on alll nite im pretty bored, if u wanan keep trying to come back with stupid comments or trying to get me mad ur wasting ur time im having alot of fun watching this.
and to answer ur question, u can either switch back to the engine ur civic orignally had or find a shop in the bay area to deal with ur wiring issues.
