No fuel, im stumped
Old Nov 15, 2004 | 02:38 PM
jdmwizz87's Avatar
Default No fuel, im stumped
I did a search and couldnt find nething to help me, so here is my situation. I have a 91 crx hf. I dropped a d16y7 out of a 97 hatch into it and for some odd reason, i now have no fuel going to the rail. I replaced the relay, checked the regulator and all of that, i also checked the wiring to the pump, everything is fine. The pump did not prime at all tho so i dropped the gas tank and replaced it with a 255lph walbro and got all of the wiring done a what not, but it is still not priming. So, i am beginning to thing it is the ecu. I did not convert from obd0, i am using a stock ecu but i converted all of the sensors on the motor to obd0. But the sensors were all good, im getting oil preasure. I am completely lost, is it the ecu or what should i do? Please help! Thanks
Old Nov 15, 2004 | 03:28 PM
crxzcracer's Avatar
From: Murfreesboro, Tennessee, United States of America
Default Re: No fuel, im stumped (jdmwizz87)
FUSE! check them all, then check all of them 43 more times! i went with out my rex for like 2 weeks and did a **** load of work cuz a blown fuse that i didnt check it was the alty. fuse
Old Nov 15, 2004 | 03:57 PM
HatchBox's Avatar
Skoobie no more...
Default Re: No fuel, im stumped (crxzcracer)
did you check the mainrelay?
Old Nov 15, 2004 | 07:29 PM
jdmwizz87's Avatar
Default Re: No fuel, im stumped (HatchBox)
I have not checked the main relay and i will do so but i have checked the fuses and they all are ok, i checked them three times and it will probably be more before i am done. But just for reference, any one know about how much a main relay runs if in fact thats the prob. And also what are some of the reasons this relay would go out?
Old Nov 16, 2004 | 07:21 AM
crxzcracer's Avatar
just so you know you my have to put a bigger fuse for the fuel pump cuz my warlbro keep blowing the stock size fuse
crookson speed
Feb 25, 2014 12:02 PM
flaco1978
Apr 19, 2006 04:49 PM
hedtrip
Feb 18, 2006 08:53 AM
DCStreetHtch
Feb 25, 2003 10:14 AM
micrew
Nov 18, 2001 09:54 PM
