B18C5 Head on B18C1 ?
Old Dec 26, 2001 | 08:47 PM
strils's Avatar
Default B18C5 Head on B18C1 ?
thinking about putting a ITR Head on my B18C1 , i have heard the compression ratio will be lower, does anyone know what it will be(with stock GSR pistons)? also is there any other special needs besides using the ITR manifold, TB and ECU ?
Old Dec 26, 2001 | 09:17 PM
ahcjar103's Avatar
Default Re: B18C5 Head on B18C1 ? (strils)
9.7-9.8:1
make sure you have all your wiring, new head gasket, new head bolts. might as well change the timing belt too.
Old Dec 26, 2001 | 11:24 PM
opusONE's Avatar
Default Re: B18C5 Head on B18C1 ? (ahcjar103)
9.6:1
Old Dec 27, 2001 | 05:52 AM
stick's Avatar
Default Re: B18C5 Head on B18C1 ? (ingenuitySi)
i thought the CR would be higher
Old Dec 27, 2001 | 10:10 AM
nugget8000's Avatar
New User
Default Re: B18C5 Head on B18C1 ? (stick)
I have always heard that the putting on a B18C5 head will lower compression because it has a larger combustion chamber, or something to that effect. I have always heard it lowers compression about .3 points. A good way to get around that is to get a mugen or spoon head gasket to compensate for the lowered compression. You will then be roughly back to the stock 10.0:1. HTH.
Old Dec 27, 2001 | 12:17 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: B18C5 Head on B18C1 ? (nugget8000)
The reason you posted is correct. A Mugen HG wont increase the comp by .4 on a GS-R motor though, it will do so on a JDM ITR motor.. which means JDM ITR pistons and ITR head. You're looking at ~.3 increase on a GS-R IIRC.
Old Dec 27, 2001 | 12:49 PM
strils's Avatar
Default Re: B18C5 Head on B18C1 ? (Dave-ROR)
ok, so the best way to maximize performance is to get some ITR pistons too or will the slight decrease in the CR not affect the overall performance that much?
Old Dec 27, 2001 | 12:50 PM
Mr. Softee's Avatar
im about to put a b16 head on my gsr block. pseudotype r baby!
Old Dec 27, 2001 | 01:42 PM
1fastGSR's Avatar
New User
your CR will drop
the cams will not be at TDC anymore. will need adj cam gears.
Old Dec 27, 2001 | 08:56 PM
strils's Avatar
anyone know performance numbers for the head on with or without the mugen head gasket on stock GSR block and pistons?
candy eg
Jun 28, 2006 01:38 PM
NoSwapNoCare
Mar 23, 2005 09:01 AM
Eluzion
May 27, 2004 05:46 AM
KRiS1
Aug 27, 2003 12:07 PM
