Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
need detail on OIL CHANGE 4 NSX
Old Nov 15, 2004 | 11:49 AM
pushinglikekrazy's Avatar
Default need detail on OIL CHANGE 4 NSX
any feed back is nice.
~ dont hate just making sure
Old Nov 15, 2004 | 12:53 PM
ak's Avatar
ak
Default Re: need detail on OIL CHANGE 4 NSX (lube2you)
You'll get a lot of hate if you fools don't learn to use the FAQ.
http://www.nsxprime.com/FAQ/DI...e.htm
Old Nov 15, 2004 | 07:50 PM
Newman's Avatar
New User
Default Re: need detail on OIL CHANGE 4 NSX (ak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ak &raquo;</TD></TR><TR><TD CLASS="quote">You'll get a lot of hate if you fools don't learn to use the FAQ.
I don't know why they have #1 on there. I'd hate to get under the NSX right after driving it hard and have hot oil pour out and splash onto you. After running the car hard, it gets pretty hot on the sides and underneath the car. That, and when you run the motor oil goes all over the engine and lubes everything. When it's cold and sits around, all of the oil has sunk to the pan and will all drain out.
Old Nov 15, 2004 | 08:11 PM
nsxtasy's Avatar
H-T Order of Merit
http://www.danoland.com/nsxgar...2.htm
Old Nov 15, 2004 | 08:43 PM
annoyed_vogon's Avatar
Default Re: need detail on OIL CHANGE 4 NSX (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">I don't know why they have #1 on there... When it's cold and sits around, all of the oil has sunk to the pan and will all drain out.</TD></TR></TABLE>
When it is cold, it is less viscous. I think the idea behind this is that more oil will drain out when it's warm.
JDM_Andrew
Feb 4, 2009 03:02 PM
bluesi07
Honda Civic (2006 - 2015)
Apr 30, 2007 04:39 PM
RemerLex11
Jul 6, 2005 03:17 PM
Vouthanack
Jul 30, 2004 11:18 AM
5-SpeedFreak
Mar 26, 2002 03:01 PM
