does 88-89 headlights and corners fit on 90-91 crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15civ »</TD></TR><TR><TD CLASS="quote">corner lights = no for sure
headlights = im thinking no</TD></TR></TABLE> im thinking its the opssosite of what you said...
EDIT::
i didnt realize he said crx..
i kno with the 88-89 corners, there are two screws on the outside part of the corner, and on the 90-91 there isnt..
my bad
my bad
headlights yes (may have to swap housing)
corners no
88-89 corners use 2 outside screws while 90-91 use clips and 1 screw under the hood
corners no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eumoria »</TD></TR><TR><TD CLASS="quote">corners no
correct me if I'm wrong, but I was told that you can use them if you switch out the clips. I've never seen behind an 88-89 corner light, but I imagine there's something plastic that the screws would anchor to. Point being, I *heard* the holes in the metal fender are in the same places.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by derekhart »</TD></TR><TR><TD CLASS="quote">Just like the discription says. I need to know if 88-89 headlight and corner assembly fits onto a 90-91 crx. please let me know thanks</TD></TR></TABLE>
it will fit as long as you make mods to your fender.... remember the difference is in the mount points between 88-89 and 90-91 and also the fender...
HmgLauj69
23
May 14, 2005 06:53 AM
zerogravitycrx
Apr 8, 2005 03:34 PM
ruiner17
Feb 16, 2003 03:29 PM
