Is ANR header a little too much????
Old Nov 15, 2004 | 08:11 AM
greenDC2's Avatar
Default Is ANR header a little too much????
I was just wondering if the ANR compact header makes good power on all cars, I know some headers are overkill for certain setups. I am considering trying one out but I was going to see what you guys think. I got 177 to the wheels with the JDM ITR header that I am currently running, would the ANR be a noticable improvement? Thanks guys.
Heres my current setup:
Stock GSR block
ITR head
S2 stage 2 cams w/str gears
S2 valvetrain
JG manifold
JG throttle body
Iceman intake
Mugen head gasket
AEM fuel rail/regulator
V-AFC w/stock ECU
Old Nov 15, 2004 | 08:32 AM
BlueTeg01's Avatar
Default Re: Is ANR header a little too much???? (greenDC2)
Those numbers seem a bit low. Skip the whole AN-R deal and go get a Toda header. With that you will see some nice gains!
Old Nov 15, 2004 | 11:58 AM
Race Egr's Avatar
Default Re: Is ANR header a little too much???? (BlueTeg01)
Is it me or did this guy ^ just say skip a an-r for a toda. An-r
All I can say is his avatar says it all
Old Nov 15, 2004 | 12:05 PM
greenDC2's Avatar
Default Re: Is ANR header a little too much???? (NAPIER)
Yea I've heard that the ANR makes better power than TODA, i've heard nothing but good about them. But would it incorporate well with my setup????
Old Nov 15, 2004 | 12:07 PM
Race Egr's Avatar
Yeah, An-r custome makes all their headers and im sure if u called them up and told them your setup they could make it to suit your setup.
Old Nov 15, 2004 | 12:08 PM
ANR008's Avatar
on a mildly modified gsr motor, weve seen our headers make 7-8 whp over aported jdm itr header. this is of course our merge collector.
our street collector makes about 5whp more then the ported jdm itr.
Old Nov 15, 2004 | 12:27 PM
greenDC2's Avatar
Default Re: Is ANR header a little too much???? (ANR008)
Yea I've seen your website and I was wondering the difference in the merge collector and the street collector, sorry I'm not familure with these differences. Also do you have to get your own flange made I'm guessing? Thanks again
Old Nov 15, 2004 | 12:40 PM
VtecKiDD's Avatar
AN-R
Old Nov 15, 2004 | 12:42 PM
Matty.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">Is it me or did this guy ^ just say skip a an-r for a toda. An-r
All I can say is his avatar says it all</TD></TR></TABLE>
LOL
Old Nov 15, 2004 | 12:46 PM
ANR008's Avatar
differences between our merge and street collectors can be seen here https://honda-tech.com/zerothread?id=906269 about 5 posts down
Old Nov 15, 2004 | 12:58 PM
greenDC2's Avatar
Flange??
Old Nov 15, 2004 | 01:05 PM
ANR008's Avatar
our headers do not come with a flange. you will have to get one welded on yourself after installation.
Old Nov 15, 2004 | 01:32 PM
HoOridin's Avatar
talkin bout overkill....u might wanna think about ur manifold ur runnin...
Old Nov 15, 2004 | 01:44 PM
hype r 555's Avatar
Default Re: Is ANR header a little too much???? (HoOridin_Kali_STyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoOridin_Kali_STyle &raquo;</TD></TR><TR><TD CLASS="quote">talkin bout overkill....u might wanna think about ur manifold ur runnin...</TD></TR></TABLE>
. i'm buying one of the merge collector/standard headers simply because i have a friend who put one of these bad boys on his car and made 9whp gain over
dc 4-1 with 2.5 flange ... and he has half the amount of work done as the setup listed ....
an-r is not overkill it's the way you should do it , esp. if you can't afford somthing like smsp or hytech ....
Old Nov 15, 2004 | 01:57 PM
JDMlyfestyle's Avatar
ANR header with merge collector and coated under a Grand.
toda Header almost the same price with less performance
AN-R
Old Nov 19, 2004 | 08:00 PM
Whitfield Inc.'s Avatar
Default Re: (JDMlyfestyle)
why worry so much about the price ---- with the cars we drive and the money we spend on them why worry about 50/100 difference in a header if one is trully better then the other
Old Feb 10, 2005 | 11:22 AM
migs's Avatar
Do these guys have a phone number?
Old Feb 10, 2005 | 11:38 AM
UncleD's Avatar
Default Re: (migs)
Your compression is much too low to run those cams. Stock block with itr head is gonna yield less compression than a stock gsr motor. I would seriously consider dropping in some pct pistons if you're gonna keep those camshafts, try to get as close to 12.1 as possible.
I am very surprised to see people saying the ANR makes power over the Toda, never heard that before....any dyno charts to back this??
Old Feb 10, 2005 | 11:48 AM
Im not sure about toda.. but the AN-R destroyed my JDM DC 4-1
Old Feb 10, 2005 | 12:17 PM
UncleD's Avatar
On the butt dyno or regular dyno??
Old Feb 10, 2005 | 12:54 PM
Bradstard's Avatar
AN-R =
Make sure you get a stainless steel version and not the mild steel.
Old Feb 10, 2005 | 01:19 PM
UncleD's Avatar
Default Re: Is ANR header a little too much???? (Fat Bradstard)
Would the ANR still be better than the Toda in a 1.6 application?? I'm still kinda questioning that...
Old Feb 10, 2005 | 02:02 PM
EF9_R_Killa's Avatar
AN-R will out flow any DC or ITR header, the guys numbers are low because the block is stock and with ITR head matted to it...that lowered compression off the start.
Old Feb 10, 2005 | 04:18 PM
DIFFUT'S INC.'s Avatar
Default Re: (EF9_R_Killa)
An-R DC JDM
Old Feb 10, 2005 | 04:20 PM
allmotorgsrekk's Avatar
dump the jg manifold to start then buy a an-r header with merge collector.
