another afc wiring question
Old Nov 15, 2004 | 07:18 AM
bipedbear's Avatar
Default another afc wiring question
alright, would this method be as affective as just tearing some wire plastic back and wrapping the wire from the afc around it?
could i just take a light blue connector, lay the ecu wire on one side, and the afc wire on the other side, and clamp that little bridge down? would that work? or would the readings be off?
Old Nov 15, 2004 | 09:43 PM
clitcomander's Avatar
Default Re: another afc wiring question (asaspicer)
the readings would not be acurate follow the instructions
Old Nov 16, 2004 | 04:57 AM
Reid's Avatar
Global Moderator
Do it right the first time.
Solder all of the connections and make sure they are insulated.
Hyaboosta
Jan 11, 2005 05:48 PM
89sib16
Mar 3, 2004 02:34 AM
