Fuel inj. resistor box?? how to test... Injectors not spraying..
Old Nov 14, 2004 | 10:39 PM
friedEGs's Avatar
Default Fuel inj. resistor box?? how to test... Injectors not spraying..
How can I test a resistor box out of my 90 ex? I have a problem getting fuel into the port. It seems like the injectors are not opening properly. Fuel is getting to the rail, and into the injector, just not spraying. Is this a sign that the resistor box has failed? Let me know any idea's, or suggestions. Thanks.
Old Nov 14, 2004 | 10:45 PM
Redline130's Avatar
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (friedEGs)
Have you cleaned your injectors lately? Perhaps their stuck. If you can, try swapping out the resistor for a known good one.
Old Nov 14, 2004 | 10:47 PM
doublethink's Avatar
i lost injector pulse on my first ECU, same symptoms you describe. you need a multimeter to check for injector pulse.
try resistor box first, if that doesnt solve it, triple check all your grounds, especially at the ecu itself, and your 12 volt inputs.
if all is in order, you might end up buying a new ecu, as i had to do.
Old Nov 26, 2004 | 07:42 PM
SiR Inspired ED7's Avatar
yO, i have a B16a in my teg and is it necassary to have a resistor box?cause i bought it with out one reason i haven't bought one is i bpught the car like a month ago and barley getting to know it....
Old Nov 27, 2004 | 06:54 AM
dr_latino999's Avatar
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (92 DA B16a)
It depends, are you running an OBD-0 system or OBD-1? You can tell by the ECU code if you don't know what is supposed to be in around the engine bay.
Old Nov 27, 2004 | 12:13 PM
CRX_Control's Avatar
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (dr_latino999)
you can still run obd1 ecu with obd0 injectors and resistor box .
Old Nov 27, 2004 | 02:04 PM
krazie1's Avatar
BANNED
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (CRX_Control)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">you can still run obd1 ecu with obd0 injectors and resistor box .</TD></TR></TABLE>
this is correct and MY current set up
Old Nov 27, 2004 | 03:11 PM
alexdog69's Avatar
if it has been a long time since the injectors were last used... then maybe you have "bad gas" in them causing them to stick closed...
try tapping on the injectors to free the stuck pintles.. i.e. take a screw driver and put it on the body of the injector and whack it with a hammer...its just like a stuck float in a carb... just be careful that you dont damage the injectors or start whacking on the plastic portions..
if its a freshly swapped jdm motor, this is not terribly uncommon...
if this gets it to start up then run your first few tanks of gas with fuel injector cleaner in it...i.e. techron or lucas...
if you want to get all tough you could take them out and bang/shake them around a bit and spray some goo in them and try to clean them...
Old Nov 27, 2004 | 04:39 PM
ef8 h0!'s Avatar
Default Re: Fuel inj. resistor box?? how to test... Injectors not spraying.. (alexdog69)
i had the same problem, switched the resistor box didnt help. id have to say main relay, that also fires you injectors.
MantisX
Engine Management and Tuning
May 20, 2010 04:24 PM
schock3
Aug 25, 2009 12:37 PM
GSRinmyCRX
May 9, 2006 04:00 PM
urname7698
Aug 10, 2005 07:33 AM
