Which amps should i go with to power my subs??? ???
Old Nov 14, 2004 | 10:34 PM
Supta's Avatar
Default Which amps should i go with to power my subs??? ???
ok,
their a 2 amps that im looking at so i can power my two 10" 500watt, 4 omes pyramid subs.. and im having a hard time picking,
the first amp hmm i forgot wat it was called.. but it has:
max power of 600watt 2 @ 2 and its a 2 channel
the second one is a MTX amp that has max power 400watt 1 @ 2 and this is a 1 channel..
i asked the guy and he said that if i go with this MTX one i would get atleast 300watt out of each of the 2 subs.. would that be bangin or what?
and the other sub.. he said that if i go the other one it would probly run at like 400 or 500watt both subs at the same time..
oh and another thing he said that with that 1 channel MTX sub, if i put the negative to positive and the positive to negative i would get better output, is that correct???
dam i dunno if u all are followin me but i need help!!1
Old Nov 15, 2004 | 07:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: Which amps should i go with to power my subs??? ??? (Supta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supta &raquo;</TD></TR><TR><TD CLASS="quote">ok,
dam i dunno if u all are followin me but i need help!!1</TD></TR></TABLE> First, the 2ch amp will not be stable at 2ohm in mono, the 2ohm rateing is in stereo, the MTX amp is the one to go with, it is a mono amp, and is stable at 2ohms, two 4ohm sobs wired in parallel, [ + of one sub to + of other sub to + of amp, - of one sub to - of other sub to - of amp] is a 2ohm load for the amp, it will "bang" 94
Old Nov 15, 2004 | 11:54 AM
Supta's Avatar
Default Re: Which amps should i go with to power my subs??? ??? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> First, the 2ch amp will not be stable at 2ohm in mono, the 2ohm rateing is in stereo, the MTX amp is the one to go with, it is a mono amp, and is stable at 2ohms, two 4ohm sobs wired in parallel, [ + of one sub to + of other sub to + of amp, - of one sub to - of other sub to - of amp] is a 2ohm load for the amp, it will "bang" 94</TD></TR></TABLE>
ok but then with the MTX sub the guy told me that if i [ + of one sub to + of the other sub to - of amp and - of one sub to - of other sub to + of amp], it would get better output cuz its a 4 omes sub. i dunno im hella comfuzed, im kinda new at this too
Old Nov 15, 2004 | 11:51 PM
Nutzurchin's Avatar
whats ur budget ? i got a very powerful ppi amp pc21400 for sale silver, its pricey though, 1400x1 4ohms rms
Old Nov 16, 2004 | 05:59 PM
lv6l's Avatar
i also have one for sale
alphasonik pma800. 1600watt at 1ohms
$200
imadigitalgod
Audio / Security / Video
Jul 30, 2006 08:54 PM
weak_tec
Jun 25, 2005 01:09 PM
tiggles187
Apr 1, 2005 12:19 PM
GroundZer0 336
Aug 14, 2003 06:49 PM
Dr Pooface
37
Jun 5, 2002 08:02 PM
