what stock intake will fit in my ef hatch
i need to know wat stock intake will fit in my 90 hatchback wit a b16 in it i have some room due to tha battery being in tha back
Well since you've relocated your battery, you can use a 92-95 Civic intake. It has less bends than a 88-91 intake.
EDIT: Sorry I didn't see stock. I think you would only be able to use an 88-91 intake system, any other years probably wouldn't fit or bolt in.
My friend has a 92-95 civic box with a 94+ integra ls tube..Works perfect
Or you can do it like this guy ..
VVVVVVVVVVVVVVVVVVVVVVVVVVVV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Count Blah »</TD></TR><TR><TD CLASS="quote">On my old ed6 i used a combination of a Integra intake tube, with a stock ED6 airbox. I had to cut about 3-4 inches off of the arm that comes out of the airbox, but once i did that it worked fine. Then I took the bottom half of the airbox, and gutted it. Had a nice growl to it that was only apparent at WOT, and was totally sedate otherwise. hth</TD></TR></TABLE>
use a JDM SiR ef stocked intake box it works great and will fit with no mods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Putput »</TD></TR><TR><TD CLASS="quote">Was wondering, on the intake arm, I notices that there are 3 holes. One that routes to the valve cover, what about the other 2 holes? Thanks.
here is my air box and it has 2 holes as you can see in the picture where they go
Strange, I don't recall seeing that on my setup. What is that thing going to on the intake manifold? I don't think that on the 92-93 Integra XSI (2nd Gen B16s).
I'm planning on using my an Integra intake tub. Can some let, please tell me what the other two holes are for?
Thanks.
Thanks.
I amn running the EF9 air box and tube. I also have the K&N drop in filter. I have my battery in the back too, and it looks very clean. BTW, for those that dont know, the EF9/8 air box and tube are bigger in diameter over the civic and even integra unit. I can only assume this translates into more airflow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Putput »</TD></TR><TR><TD CLASS="quote">Strange, I don't recall seeing that on my setup. What is that thing going to on the intake manifold? I don't think that on the 92-93 Integra XSI (2nd Gen B16s).
Thanks.</TD></TR></TABLE>
i believe its a vaccum line and its from an EF9
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 »</TD></TR><TR><TD CLASS="quote">..... BTW, for those that dont know, the EF9/8 air box and tube are bigger in diameter over the civic and even integra unit. I can only assume this translates into more airflow.</TD></TR></TABLE>
Ive heard that the EF8/9 air box beats any after market cold air/ air intake
red civic standard
Apr 16, 2002 12:27 PM
