high fuel pressure??
Old Nov 14, 2004 | 10:00 PM
rtpassini's Avatar
Default high fuel pressure??
what would cause my fuel pressure to go up? i put an h23 in my sol. and recently i shortened up my fuel line hose because it was really long. i just barely losened a clamp and gas came shooting out. and im also running extremely rich with some idel problems. so im guessing this might be a factor. the engine is stock.except a short ram. and im using the stock ecu. any ideas?
Old Nov 14, 2004 | 10:30 PM
eda6's Avatar
Default Re: high fuel pressure?? (rtpassini)
Vacuum hose from the fpr hooked up improperly. Blown fpr comes to mind. Kinked return line?
What's your fuel pressure? How did you shorten the fuel supply line?
Old Nov 15, 2004 | 09:35 AM
rtpassini's Avatar
my vacuum line looks okay. return line seems fine.
i have no clue what my fuel pressure is actually at. i dont have a gauge.when you put an h series in an eg. or del sol. you have you lengthen the line. and when i first put it in. i had too much slack. so we just took some of it off.
Old Nov 16, 2004 | 07:41 PM
rtpassini's Avatar
man you cant ask questions and then not reply after i answer them lol
Old Nov 17, 2004 | 05:18 AM
JimBlake's Avatar
Default Re: (rtpassini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtpassini &raquo;</TD></TR><TR><TD CLASS="quote">i have no clue what my fuel pressure is actually at. i dont have a gauge...</TD></TR></TABLE>If you're chasing a problem of running rich, & you 'think' your pressure is too high, maybe you ought to get a guage. It's a lot better than guessing.
Old Nov 17, 2004 | 04:48 PM
slowsleeper's Avatar
Default Re: (JimBlake)
yeah, maybe just get a b=m fpr and gauge set, not sure if they're accurate but can be had for cheap like 50 bucks or something
97mm_EH3
Apr 12, 2011 05:31 AM
polishedturd
54
Jun 5, 2008 02:00 PM
hybrid_vtec
Aug 27, 2004 10:02 AM
IgniteTeg
May 29, 2002 11:08 PM
