should i upgrade my fuel pump?
i just got a free Walbro fuel pump from my friend, that is a direct drop in for the stock pump . i think it flows like 255 LPH. i want to know if i should install it or if it's not necessary with my setup.
I have a 97 LS with I/H/E, B&M FPR, CROWER 403 cams, SKUNK2 cam gears, SAFC, stock injectors, and soon will be installing PR3 pistons. would i run extremely rich if i install this fuel pump? or dont even bother install n it?
thats would a alot more fuel than you would ever need. Im running a 195 on mine and still dont use it to its full capacity.
If you do decide to use it, you can adjust it with your FPR but I think maybe the 255 would be to much for the B&M FPR , it might overrun it but I could be wrong.
