ctr s2s1 cams with nitrous
Old Nov 14, 2004 | 07:19 PM
typesguy's Avatar
Default ctr s2s1 cams with nitrous
any running ctr or skunk2 stage 1's with nitrous. im think i want to run a 65 shot on my car.how does ctr and s2s1 react to nitrous.
setup
b18c1
-cai
-dc 41 header
-high flow cat
-2.5 cateback exhaust
-stage 2 clutch
-8.5lbs flywheel
-skunk2 stage 1 cams
-skunk2 cam gears
-fields vtec controller
Old Nov 14, 2004 | 08:00 PM
631 Teggy's Avatar
Default Re: ctr s2s1 cams with nitrous (jaydmdc2)
Wrong forum man... This belongs in the forced induction forum
Old Nov 14, 2004 | 08:09 PM
BlackRocket's Avatar
Hopefully this will help a little.
https://honda-tech.com/zerothread?id=1050636
Old Nov 14, 2004 | 08:15 PM
typesguy's Avatar
Default Re: (SprayinR21)
thanks man
Old Nov 14, 2004 | 08:20 PM
hondaeg8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SprayinR21 &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully this will help a little.
yeah....but that thread is about using bigger cams than the ctr's are s2s1's.
i have a ctr intake cam in my jdm gsr motor and i have a 60 shot, but i haven't sprayed since i installed the cam. i wouldn't see having those cams hurting anythign when spraying though.
Old Nov 14, 2004 | 08:23 PM
i didnt put it there to solve all of his problems i just posted it so he got a look at a different setup and how that was reacted to. the stg 1 cams will react the same as your stock cams pretty much b/c they are not that big of an upgrade
Old Nov 14, 2004 | 08:29 PM
hondaeg8's Avatar
right, but there will be different answers when refering to a smaller cam than to a bigger cam.
i don't see a problem when using the smaller cams with spray either. maybe i'll find out soon, but i don't really use the bottle, its just there.
Old Nov 15, 2004 | 11:05 AM
JSpin's Avatar
Default Re: (hondaeg8)
i'm using blox 1 cams in my direct port setup
easycheese
Feb 23, 2008 11:06 AM
slimjimdanny
Mar 24, 2007 09:16 AM
JdmFront619
Jan 25, 2004 05:58 PM
joek84
Jul 28, 2003 06:42 PM
