can i fill tranny thru backup light switch hole?
Old Nov 14, 2004 | 07:17 PM
JCracer723's Avatar
Default can i fill tranny thru backup light switch hole?
the freakin fill up bolt wont come off.. and the freakin vss thing wont come off either..
so can i take off the back-up sensor and fill the tranny thru there??
Old Nov 14, 2004 | 07:36 PM
down_the_hatch's Avatar
Default Re: can i fill tranny thru backup light switch hole? (JCracer723)
yea u can, but i dont think its good to. i did it cuz someone told me i can, but u gotta try gettin that bolt off next to where the axles go in. its a 17mm. if u do it through the back up light switch u wont know if u filled the tranny up all the way. so thats why u dont wanna fill it up there.
Old Nov 14, 2004 | 07:37 PM
Default Re: can i fill tranny thru backup light switch hole? (uglyasscrx)
and u dont wanna overfill or underfill it
Old Nov 14, 2004 | 07:47 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uglyasscrx &raquo;</TD></TR><TR><TD CLASS="quote">yea u can, but i dont think its good to. i did it cuz someone told me i can, but u gotta try gettin that bolt off next to where the axles go in. its a 17mm. if u do it through the back up light switch u wont know if u filled the tranny up all the way. so thats why u dont wanna fill it up there.</TD></TR></TABLE>
that 17mm bolt is the one that wont come off.. i guess ill just pour what the manual says..
btw was that back up light sensor hard to come off?? what size open wrench did u use? 17?
Old Nov 14, 2004 | 07:51 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">
btw was that back up light sensor hard to come off?? what size open wrench did u use? 17? </TD></TR></TABLE>
You can get it off. Mine was hard to get off too. I put the 17mm wrench on there and let a 4lb. hammer do the rest.
Old Nov 14, 2004 | 07:53 PM
JCracer723's Avatar
Default Re: can i fill tranny thru backup light switch hole? (eda6)
trust me i tried it... i even tried a trick using the jack.. and it wont even move an inch..
Old Nov 15, 2004 | 12:21 AM
B2FiNiTY's Avatar
Yep, that is what I did when the fill bolt wouldn't come loose.
Old Nov 15, 2004 | 06:50 AM
boxybutfast's Avatar
I almost destroyed mine taking it off, but it finally came. I put it back in loosely (comparatively speaking) while I order a new one from Honda (about $3.50). I mean I almost tore my own arms off trying to get that bastard loose. I was actually moving the car! No, I mean physically moving it across the ground by pulling on the stupid ******* bolt!
Do yourself a favor and put just a little anti-seize on the threads before it goes back in. Steel bolt, Aluminum tranny, it gonna corrode eventually. Anti-seize is your friend!
TIP: Only use a 6 point socket or wrench, no 12 pointers!
Old Nov 15, 2004 | 08:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
Put wrench on bolt. Grab side of car and slide legs underneath. Push on wrench with foot. It will come loose with enough toying. Or just get a 1200 ft-lb air impact on it.
But yes you can fill it though there.
I fill through my VSS hole. I still remove the 'fill plug' to check for proper fluid level.
Old Nov 15, 2004 | 01:56 PM
JCracer723's Avatar
Default Re: (DaX)
thanks all.. i just finish doin it.. the sensor come off quick.. and it was easier to fill from there than bein under the car.. making a mess..
guero2craze
Jun 4, 2007 05:10 PM
crxmadman
Mar 9, 2006 12:10 PM
Reelizmpro
Oct 10, 2004 02:14 PM
hatchling37
Jun 25, 2004 08:27 AM
Dspad_91Civic
Jun 23, 2004 12:14 PM
