B16 with ITR internals
Old Nov 14, 2004 | 06:36 PM
civichatchB18MO's Avatar
Default B16 with ITR internals
First of all whats up everybody.. i have a 89 crx si.. its pretty striped.. but ne ways.. heres my problem.. i have a B16 block.. im getting ITR internals.. u know.. pistons,rods and crank... now will those work in the b16 block?.. thanks guys ne help would help
Old Nov 14, 2004 | 06:41 PM
nonemulatory's Avatar
Default Re: B16 with ITR internals (CRXB16MO)
yes it will all bolt on ... b series into any other b series =
Old Nov 14, 2004 | 06:46 PM
Default Re: B16 with ITR internals (nonemulatory)
ok thank god.. because people were telling me that ITR parts wont match up because the B18C5 block is taller
Old Nov 14, 2004 | 07:02 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXB16MO &raquo;</TD></TR><TR><TD CLASS="quote">ok thank god.. because people were telling me that ITR parts wont match up because the B18C5 block is taller</TD></TR></TABLE>
Dont take his advice just yet. let some other members chime in.
I know quite a few have done this, but im unsure if you need a thicker head gasket...
Old Nov 14, 2004 | 09:20 PM
daa90crx's Avatar
Default Re: B16 with ITR internals (HatchBox)
hahaha no it will not work quite right because the b18 is a longer block so you would probably have to cut the rod or do something but it wont just bolt up and run u have to customize some stuff and thats all i know haha
Old Nov 14, 2004 | 09:40 PM
boostaddict.com's Avatar
hey whats up? daa90crx is right the b18 block is longer. my ls crx just beat a b16 hatch with a fully built ITR head reving to about 8800. in other words if you havent bought the parts yet then dont just turbo the bitch.
chad
Old Nov 14, 2004 | 09:51 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonemulatory &raquo;</TD></TR><TR><TD CLASS="quote">yes it will all bolt on ... b series into any other b series = </TD></TR></TABLE>
Oh really, I love miss information special when its crucial information like that, so your also saying b16 pistons will fit in a b20 ? You can use the pistons but you can't use the rods, you have to use the b16 rods and shave 1mm off each side. And since your using the b16 rods, use the b16 crank.
Old Nov 15, 2004 | 03:37 AM
HatchBox's Avatar
Skoobie no more...
Default Re: B16 with ITR internals (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Oh really, I love miss information special when its crucial information like that, so your also saying b16 pistons will fit in a b20 ? You can use the pistons but you can't use the rods, you have to use the b16 rods and shave 1mm off each side. And since your using the b16 rods, use the b16 crank.</TD></TR></TABLE>
see told ya to wait for good members to chim in
Old Nov 15, 2004 | 04:04 AM
Kaan's Avatar
Loved
Community Favorite
use the pistons, valves, retainers and springs... but you shoulda gone CTR with it all and clayed the motor when you built it to get the tolerences and reliability back
Old Nov 15, 2004 | 05:26 AM
Default Re: B16 with ITR internals (MMsportsRexSi)
ok.. well i was talking to some shops here in Kansas City and they all said that it would work.. it makes the b16 a stroker or something to that effect.. and the guy im buying them from has pics of the whole setup in the b16a2 block... but has ne one ever done this or heard of nebody doing it?
Old Nov 15, 2004 | 06:09 AM
dr_latino999's Avatar
Not as a direct bolt in, you will need machining to the parts in question if they haven't already been modified.
Old Nov 15, 2004 | 06:27 AM
slowpokesi's Avatar
Default Re: B16 with ITR internals (dr_latino999)
It will not work, the rods are to long, you can use ctr rods if your that adament about it, but really why waiste your money on it when you can buy better pistons and rods that will make more power and they will fit? Why try to rig it to fit?
Old Nov 15, 2004 | 06:30 AM
HamiltonRex's Avatar
Default Re: B16 with ITR internals (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">It will not work, the rods are to long, you can use ctr rods if your that adament about it, but really why waiste your money on it when you can buy better pistons and rods that will make more power and they will fit? Why try to rig it to fit?</TD></TR></TABLE>
Agreed.
They wont work! The b18c deck is higher, You need custom length rods to use the b18c crank in your b16.
Old Nov 15, 2004 | 06:36 AM
Default Re: B16 with ITR internals (HamiltonRex)
I believe it is the ITR bling factor that is influencing this decision.
Old Nov 15, 2004 | 06:41 AM
slowpokesi's Avatar
it must be, NA is so overrated, ive been na for 2 years and finally switched to the darkside, i cant believe how much time and money i wasted on "na"
so im a bit biased, but dont waste your money on itr crap , if your dead set on na and want rods and pistons, get some eagle rods and some endyne/wiseco pistons and call it done!
tteal ddx
Jul 13, 2006 04:14 PM
shitycivic
Sep 22, 2005 04:16 PM
LSEGHATCH
Mar 2, 2005 02:46 PM
PsychoSiRex
Mar 6, 2003 05:19 AM
mellowboy
Dec 12, 2002 11:48 AM
