why the hell all my 4 wheel brakes locked up when i...
Old Nov 14, 2004 | 05:53 PM
4DRmafia's Avatar
Default why the hell all my 4 wheel brakes locked up when i...
put on my new brake booster and master clyinder..? wtf happen here
Old Nov 14, 2004 | 06:20 PM
b0pIT's Avatar
Default Re: why the hell all my 4 wheel brakes locked up when i... (SkipMic2006)
The clearance could be off between the booster and the master cyl pushrod. the booster might be pushing on the breaks all the time if theres no clearance.
xci_ed6's Avatar
you need to adjust the pushrod, it is set too long
Old Nov 14, 2004 | 06:23 PM
4DRmafia's Avatar
my pedal right now is loose and not pressing on the booster at all...
Old Nov 14, 2004 | 06:30 PM
CRXSIR1's Avatar
Check here http://www.binghamtonlife.com/...4.jpg My son had problems with all 4 brakes draging. The booster had to be adjusted. He has no brake drag now
Old Nov 14, 2004 | 06:45 PM
4DRmafia's Avatar
i dont even know how to use that thing or have the tools i plan just put on my old booster back on with my new master clyinder ...will that work at least?
Old Nov 14, 2004 | 07:04 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (SkipMic2006)
take off the prop valve.
and i think the pushrood is in the prop valve, i think you can just screw it to tighten it, im not sure, but trial and error, unless you go to autozone and get the 3-4 dollar peice to see propper clearance.
Old Nov 14, 2004 | 07:06 PM
4DRmafia's Avatar
well my old stock booster and clyinder works great until after i install this 2 new parts then it just locked up
Old Nov 14, 2004 | 07:07 PM
4DRmafia's Avatar
i am thinking it has something to do with the booster...
Old Nov 14, 2004 | 07:17 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">i am thinking it has something to do with the booster...</TD></TR></TABLE>
its the pushrod.... have it adjusted or do it yourself and you will see..
Old Nov 14, 2004 | 07:28 PM
4DRmafia's Avatar
adjust at where ? at where i put the pin in for the arm ?
Old Nov 14, 2004 | 07:51 PM
rice_classic's Avatar
Default Re: why the hell all my 4 wheel brakes locked up when i... (CRXSIR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">adjust at where ? at where i put the pin in for the arm ?</TD></TR></TABLE>
When you make a thread it's sometimes a good idea to read the actual posts that are in it. There is no need for this question, you're answer was already posted.
Ta Da:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXSIR1 &raquo;</TD></TR><TR><TD CLASS="quote">Check here http://www.binghamtonlife.com/...4.jpg My son had problems with all 4 brakes draging. The booster had to be adjusted. He has no brake drag now</TD></TR></TABLE>
Old Nov 14, 2004 | 08:09 PM
HatchBox's Avatar
Skoobie no more...
Default Re: why the hell all my 4 wheel brakes locked up when i... (rice_classic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic &raquo;</TD></TR><TR><TD CLASS="quote">When you make a thread it's sometimes a good idea to read the actual posts that are in it. There is no need for this question, you're answer was already posted.
Ta Da:</TD></TR></TABLE>
haha i was just going to repost that link.
Old Nov 14, 2004 | 09:25 PM
b16_madman's Avatar
Default Re: why the hell all my 4 wheel brakes locked up when i... (HatchBox)
haha, yeah read what's posted
Old Nov 15, 2004 | 12:55 PM
4DRmafia's Avatar
sorry i was just fustrated ..
jofat91
May 14, 2011 10:40 PM
efsex
Aug 19, 2010 02:34 AM
OMGhi2u
Mar 23, 2008 12:01 AM
Crimson_Tide
Jan 23, 2006 05:36 AM
