Bushings??
Old Nov 14, 2004 | 05:48 PM
96lewd's Avatar
Default Bushings??
I have a 1996 Prelude with about all of the bushings in some way damged. I am going to replace them, my question is just, what setup would you suggest (I want a full bushing kit), how long will it take, how hard is it, and could I do it myself if I have never done it before. Or should I fork over the money and have a shop do it. The reason I am doing this is because I have Koni yellows in the back and KYB AGB in the front, I was told that these can go from very stiff to very smooth. I have changed them however and they dont move in their stiffness. I believe it has something to do with the bushings. Any suggestions will help, thanks.
Old Nov 14, 2004 | 06:19 PM
SuperSlow's Avatar
Default Re: Bushings?? (96lewd)
If you are talking about ride quality, bushings have nothing to do with damper rate adjustment.
If you are talking about replacing your bushings with polyurethane, there have been many good threads that already cover this topic. Even recently. Maybe someone will tell you how to find them.
Old Nov 14, 2004 | 06:20 PM
BlissSkr's Avatar
if u changed the setting on the struts and the stiffness or softness didnt change most likely the struts themselves are gone.
Old Nov 21, 2004 | 05:48 PM
djbrandonr's Avatar
https://honda-tech.com/zerothread?id=1039640
Honda Type R
14
Jul 13, 2015 07:34 PM
Folfin
May 31, 2012 06:26 PM
red01teg
Aug 8, 2006 01:26 AM
Bay_707
Suspension & Brakes
Jul 24, 2005 07:41 PM
tthomass
Suspension & Brakes
14
Mar 4, 2005 09:44 AM
