93 integra wont start !!!!!!!!
well im bout to pick up a 93 integra ls for a winter beater tomm but it wont start the car was running fine......but then stalled and wont start back up.......the car is not getting anyspark or fuel!!!!! you can not hear the fuel pump even kick on ......tried to replace te ecu but still doing the same thing!!!!!! any help will be greatly appreciated ....... ive searched and seems like this problem has happened to lots of people in the past 3 years but yet no awnsers of what it was they had to do to fix it ....... rember the car is getting no spark and no fuel!!!!!!!!
ummm don't wanna high jack your thread but I'm kind of having the same problem any help will be great.
My car starts but when it warns up it dies on me and won't start also starter won't work after cars dies. I hit the stater and I get start but car don't crank starter keeps going out and seems like car is getting no gas or sparks plus starter what's going on!
Helps us
Helps us
no fuel, most likely your main fuel relay. do you hear it prime when you turn the key to the ii position before it cranks? if not check the relay the solder may have broken which is what happens and needs to be resoldered.
no spark, check your coil and ignitor, they are notorious for going out in our cars. open up your distributor and check them with a multimeter or take them out and bring them to autozone or napa and have them test it for you. also have you change the cap and rotor?
ok well i just have been messing with the car changed the main realy still no fuel nore any spark the fuel pump isnt priming at all the engine light stays on when i was searching i saw people asking if the engine light stays on or goes off but yet going back to 2001 in my search no one has posted a solution of what is in need of fixing
I'm working on my car right now I'll let you know if I find the problem. Since my starter went out I'm replacing that first but when started was working the car wouldn't crank so I'll check everything else and let you know!!
ok I replaced the starter and the car started fine I had it running for about 20 minutes and then I turn it off.
But when I went back to try to start it it happened again there was start but no turn on.
I have a hondata tuned
Walbro In-line fuel pump
600cc injectors and aem regulator
Turns out the car won't start because there is too much gas going in
I turned the pressure down to 39 PSI on the aem still no start
Should I disconect the fuel pump???
My car is boosted I don't know what to do I will try to start the car with out fuel pump but is that going to mess up the hondata program the way it was tuned. Because if I do this car will run on stock fuel set up with 600cc injectors.
I was thinking maybe the distributor but if the car started fine when starter was installed then I'm thinking is only fuel but again it could be both I have no idea I need help!!
well since you changed parts to working parts, it looks like you're gonna have to chase wires. unless the ecu is throwing codes. but if it isn't then follow all your wires from your distributor and see if there are any cracks or cuts and check the wiring to your fuel pump. thats the best i could come up with. good luck and hope you get your car running.
yuri
yuri
no spark, no fuel?!
are you sure? pull out the injectors and hold a large clear bag like a ziplock over the injectors and turn the car on and see if they spray, you need to people for this and the next one i am gonna say, one to start and you watch. and also pull a plug out and rest the side of it on the block for a ground and have someone turn your car over and look for spark, and it should be a blue spark, not a weak yellow one...
if no spark at all, you're looking at a bad ignitior (usually anyways) or a weak spark which is what i am working with, i believe it to be a bad dist. (i.e. bad pickup in the dist. which is un-replacable through an auto parts store...)
my car has no fuel at all you turn the key and nothing you dont hear the pump kick on at all........
my car has no spark at all....... i strongly think there is one thing causing it but what it is i have no clue??????
the car has new distributor and a new main realy but still no fuel nore and spark!!!!!!!
just because you don't hear it turning on doesn't nessicarily mean it's not. my rabbit fuel pump does not turn on until you attempt to start the car and iknow the pump is not bad cause i get 95psi coming in at the fuel rail.
and if it is a fuel problem and not a spark then how would you know that's you're not getting spark?
seriously man, try something rather than sitting and automatically saying oh that's not it, that's not it can't be that either, i seriously must have had my whole ignition system apart on my teg about 15 times, no joke trying many different things and i got it today. and if i didn't today i wasn't planning on quitting next was the MSD box, but i ended up being abot to not have to do it..
i wish the best of luck with it and hope you get it running, but it's not going to run if you don't troubleshoot and don't keep at it...
