B20a/vtec pics
Old Nov 14, 2004 | 04:00 PM
boost_guy's Avatar
Default B20a/vtec pics
I was wondering if anybody has ever done a b20a/vtec swap and has pictures? I have seen the ludespeed setup and they couldn't seem to keep there's running. I have heard people say that they have seen this setup but I want to know if anybody has pics to prove it.
Old Nov 14, 2004 | 04:58 PM
mgags7's Avatar
why would you put a b20 vtec in a prelude? just asking b/c its in the lude forum....i dont think anyone has done this in a prelude, go talk to the civic guys
Old Nov 14, 2004 | 05:08 PM
PRCLude98's Avatar
Default Re: B20a/vtec pics (boost_guy)
I've seen this setup but I don't have a pic of the car. I do know that the guy said he had a lot of trouble with it though.
Old Nov 14, 2004 | 05:58 PM
incubus's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">why would you put a b20 vtec in a prelude? just asking b/c its in the lude forum....i dont think anyone has done this in a prelude, go talk to the civic guys</TD></TR></TABLE>
its a b20a he is talking about, which comes in the 3rd gen ludes 88-89... b20b and b20z are the engine codes for the CRV motors.
HMM its interesting, but the b20a and b21a dont have too much in common with the rest of the Bseries family which is probably why they are having so many problems.
Old Nov 14, 2004 | 06:00 PM
incubus's Avatar
Default Re: (incubus)
**** I say if ou really want a b20/vtec to just get a b20b or b20z n a b16 head, motor mounts would prove to be the difficult part. A b21 tranny should bolt right up to the b20b/z block.
or u could just h22 it. nothing like starting with a stock motor for reliability.
Kal's Avatar
Kal
best bet is to turbo the sucker. all else is not cost effective and troublesome.
Old Nov 14, 2004 | 06:13 PM
momstaxi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incubus &raquo;</TD></TR><TR><TD CLASS="quote"> A b21 tranny should bolt right up to the b20b/z block.</TD></TR></TABLE>
it will not.
Old Nov 14, 2004 | 07:25 PM
boost_guy's Avatar
Default Re: (momstaxi)
http://www.imagestation.com/album/?id=2287605093 here it is. It's in my garage right now, I can list the mods, the list in the picture is not quite up to date. It's an 89 si. Pulls hard all the way to 11k, jdm b20a tranny w/ an ITR lsd modded to fit the b20 ring gear. You will have to sign up to view the pics though, sorry.
o yeah by the way here is a link of it turboed http://www.imagestation.com/album/?id=4290381973
Modified by boost_guy at 8:38 PM 11/14/2004
Old Nov 14, 2004 | 10:19 PM
boost_guy's Avatar
Default Re: (boost_guy)
B20a block, eagle sleeves, 82.5mm bore, Scat h22 rods, custom forged pistons, total seal rings, custom eagle destroked crank, CTR head with DPR port and polish, 1mm oversize titanium valves, titanium valvesprings and retainers, JG race cams, Toda bearings, Toda timing belt, AEM cam gears, Act 9 lb flywheel, Clutch Masters stage 3 gsr clutch, JDM B20 tranny with ITR LSD, Venom intake manifold, JG 68mm throttle body, vortech fuel rail, Rc engineering 370cc injectors, B&M fuel pressure regulator, Walbro 255 fuel pump, custom header, 2 1/2" exhaust with magnaflow muffler, 3" short ram intake, Zex 75 shot, full msd ignition, chipped pr3 ecu, brembo big brake kit front and rear, 1 of 9 carbon fiber hood, H&R race springs with KYB struts. I think there is more but I can't remember it all right now. 2600 miles so far and no problems, runs awesome and pulls hard as hell.
Old Nov 15, 2004 | 02:48 PM
boost_guy's Avatar
I thougth that at least one person on here would want to know how it was done. I've read a lot of threads where people say it not possible. I thought that there would be some more interest than this. Should I move this to a different forum?
Old Nov 15, 2004 | 05:28 PM
PirateMcFred's Avatar
It is cool that you did do it but you have so many mods that are custom it sounds DAMN expensive to replicate. Pics is what I would be interested in. MMMM Internals.
Pirate
Old Nov 15, 2004 | 08:43 PM
boost_guy's Avatar
Default Re: (PirateMcFred)
It wasn't really that expensive. It cost about the same as building any other engine. The hardest part was probably the head gasket and modding the head to fit the block. I don't have any pictures of the internals but I do have the pics of it all assembled. Maybe some time next month I can dyno it. If I do I'll post it. I can't prove that it's a built bottom end, but is a stock b20a bottom end going to handle 11k plus rpm's and a 75 shot? Probably not.
Old Nov 17, 2004 | 06:54 PM
b20aNMD's Avatar
Actually I'm interested, and must say, I give you props. I have an 89 4WS Si with the stock B20A5. I'm not ready for an engine swap, as I'm partial to what I have now. I have a question though, if you don't mind. I'm planning on boosting, so I"m going through the steps to strengthen my setup. I've heard through several sources that 460cc injectors are a reliable size for my engine, and future modifications. Did the swap last night with disappointing, yet not surprising results. The computer will not lean out the mixture enough, and even with the timing advanced she's dumping. We're talking tear gas from the tail pipe here. Any suggestions on how to lean her out more until I install the turbo, or did I jump the gun with this mod?
Old Nov 18, 2004 | 04:30 AM
boost_guy's Avatar
Default Re: (b20aNMD)
You need some way to compensate for the bigger injectors, like an safc. Most ecu's can only compensate for about a 10% increase in injector size, and you have way more than that.
Old Nov 18, 2004 | 03:01 PM
b20aNMD's Avatar
Thats' what I figured, actually. I do feel like I jumped the gun on this mod, but it's not my daily driver so back to the drawing board. It's not too much trouble do you have any suggestions or links for a good safc? Thanks for the help.
SilverPanda
Nov 13, 2005 07:15 PM
getzy3
May 3, 2005 03:08 PM
TeaAddict
Jan 13, 2005 08:57 AM
cookci
Apr 25, 2004 10:35 AM
mcandrews
Jul 4, 2003 02:10 PM
