B-series Dizzy questions
Old Nov 14, 2004 | 03:33 PM
crxgsr91's Avatar
Default B-series Dizzy questions
I just found out I have an LS dizzy on my B18C swap. My question is, are the dizzy's the same or close enough to not be causing my engine misfire?
Old Nov 14, 2004 | 03:39 PM
CrazyKoreanCrx's Avatar
Default Re: B-series Dizzy questions (crxgsr91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">I just found out I have an LS dizzy on my B18C swap. My question is, are the dizzy's the same or close enough to not be causing my engine misfire?</TD></TR></TABLE>
I think it would cause the misfire and do you even get spark? Are you sure you have the LS dizzy and do you have the dizzy number?
Old Nov 14, 2004 | 03:43 PM
crxkane's Avatar
the dizzy are not the same, if you have a vtec motor with a ls dizzy on you have to hack off one of the legs to make it fit. it will work like this but most will say that you can not adjust the dizzy. this is how i ran on my 1st b16 swap on my crx for over a year then got a jdm b16 obd0 dizzy. i had no misfire or problems with this.
Old Nov 14, 2004 | 03:48 PM
crxgsr91's Avatar
Default Re: B-series Dizzy questions (CrazyKoreanCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyKoreanCrx &raquo;</TD></TR><TR><TD CLASS="quote">
I think it would cause the misfire and do you even get spark? ?</TD></TR></TABLE>
Yes I get spark, in fact I have been driving it around for about 6-months.
Are you sure you have the LS dizzy and do you have the dizzy number?</TD></TR></TABLE>
I went to the autoparts store for a cap and rotor and the cap did not fit. But the non-vtec cap fit perfectly. I bought the dizzy from locashracing so I have no clue what they did about the post problem( but it has three mounting posts).
Old Nov 15, 2004 | 04:30 AM
crxgsr91's Avatar
Anyone else know if the Dizzy is the cause of my problems?
eye.ha8.u
Aug 1, 2006 12:54 PM
thenick
Feb 8, 2006 10:00 AM
rediculous
19
Apr 13, 2005 09:31 AM
RACING INTEGRATION
Oct 27, 2004 06:52 AM
joey1320
Oct 26, 2004 04:21 PM
