Tire Fitting question....
will any 15" tire fit a 15 inch rim? because i bought these 15 inch rims from a junkyard and want to put tires on them, the inside of the rims, from inside of the lip to the other side is almost 7 inches give or take, so do i have to be weary in buying rubber or will most 15 inch tires fit?
nooo they all won't fit. If the wheel is a 15x7 then you will have to go with a 205 wide tire or 215 wide and the sidewall height is up to you maybe a 50 series or 55 series would be your best bet!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crstfr14 »</TD></TR><TR><TD CLASS="quote">nooo they all won't fit. If the wheel is a 15x7 then you will have to go with a 205 wide tire or 215 wide and the sidewall height is up to you maybe a 50 series or 55 series would be your best bet!</TD></TR></TABLE>
actully u can go with a 195 cause on mine i am running a 195/50/15 and its 15x7
alot of people run 195/55-15 or 205/50-15
