What exactly do I need to paint my spoiler?
its currently painted stock PY. I need to paint it ssbp. After running some searches alot of people resort to having shops doing their paint. I want to attempt the prep and paint myself. I just need to find out exactly what needs to be done in detail.
Heres the general idea I have...
wet/sand down the clearcoat with a fine grit sand paper (600, 1000)? then just reuse the factory basecoat then spray using b90p in a rattle can?, then spray clearcoat?
basic instructions....
body work...like bondo and makin it straight narrow....
40 grit....80 grit
primer
320 grit
400 wet sand
seal it
spray it
I do this all day long at the body shop i work at and it seems to do the trick good luck. Also get your paint code matched spray cans...all that combinded and some skill u will be stokec.
40 grit....80 grit
primer
320 grit
400 wet sand
seal it
spray it
EricUSC
Mar 8, 2006 01:26 PM
