Anyone with a helms manual - help
Old Nov 14, 2004 | 02:11 PM
sykotic's Avatar
Default Anyone with a helms manual - help
Any of you guys have a helms manual? If so, could you scan the page with the ECU Pinouts for the P75 ECU showing what each pin goes to? It would help me a great deal hooking up my wideband o2.
Old Nov 14, 2004 | 05:33 PM
sykotic's Avatar
Default Re: Anyone with a helms manual - help (sykotic)
please?
Old Nov 14, 2004 | 06:51 PM
IVI's Avatar
IVI
i searched on here and found this.
http://tech2.hybridgarage.com/..._obd1
should be a help.
what are you trying to do maybe you can get more help.
Old Nov 14, 2004 | 06:52 PM
RidinStock's Avatar
Default Re: Anyone with a helms manual - help (IVI)
http://www.hondahookup.com/manuals/
Check there... that's where I got mine.
Old Nov 14, 2004 | 07:01 PM
IVI's Avatar
IVI
Default Re: Anyone with a helms manual - help (RidinStock)
nice site, im downloading 3 things right now .
Old Nov 15, 2004 | 04:03 AM
sykotic's Avatar
Well I found out that the harness's are C408, C409, C410... but I can't seem to find the diagram for the harness's showing which color does what, what page did you find it on?
Old Nov 15, 2004 | 03:52 PM
sykotic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">i searched on here and found this.
[url=http://tech2.hybridgarage.com/ecu.php?ecutype=p72_obd1]
should be a help.
I need to find out what each wire is to install my wideband o2 sensor, the site you gave is for a p72, I have a p75 cause I have an LS =/. That manual is great but it doesn't tell what each wire is, it just shows what color the wire is for each pin... doesn't make alot of sense because I can just look at my harness and see what color they are, need to know what each of them does.
Old Nov 16, 2004 | 04:59 AM
JimBlake's Avatar
What year LS? My '95 Helm book only has one set of wiring for LS & GSR. It simply indicates which circuits are 'B18C1 only' or 'auto-tranny only' or whatever. That says the basic pinout is the same, just a couple added wires where the LS has empty spaces.
Old Nov 16, 2004 | 03:33 PM
sykotic's Avatar
but still that manual only tells what color each wire is for the harness, it doesnt say what each wire DOES.
sykotic's Avatar
Default Re: (sykotic)
I have a 95 as well
Old Nov 17, 2004 | 03:41 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 95 as well</TD></TR></TABLE>
A01 INJ1 (brn) injector 1 (close ground to fire)
A02 INJ4 (yel) injector 4 (close ground to fire)
A03 INJ2 (red) injector 2 (close ground to fire)
A04 VT SOL (grn/yel) VTEC solenoid valve (B18C1 only)
(VTEC solenoid valve is self-grounded)
A05 INJ3 (blu) injector 3 (close ground to fire)
A06 O2SHTC (orn/blk) O2 sensor heater (close ground to turn on)
A07 FLR1 (grn/blu) fuelpump relay (close ground to run)
A09 IACV (blk/blu) idle control valve (close ground)
A12 FANC (grn) radiator & condenser fan relays
A13 MIL (grn/orn) MIL lamp (close ground to light)
A15 ACC (blk/red) A/C clutch relay
A16 ALT C (wht/grn) alternator (control?)
A17 IAB CS (pnk/blu) IAB control solenoid valve (B18C1 only)
(yel/blk) IAB powered from term.2 of main relay
A19 FAS (yel) to TCM (auto trans only)
A20 PCS (red) EVAP purge control solenoid valve
A21 ICM 1 (yel/grn) to ICM
A23 PG1 (blk) power supply ground G101
A24 PG2 (blk) power supply ground G101
A25 IGP1 (yel/blk) 12v power from main relay (2)
A26 LG1 (brn/blk) ground G101
B01 IGP2 (yel/blk) 12v power from main relay (2)
B02 LG2 (brn/blk) ground G101
B03 AFSA (grn/blu) to TCM (auto trans only)
B04 AFSB (gry) to TCM (auto trans only)
B05 ACS (blu/red) A/C switch
B07 ATP PN (lt grn/blk) auto trans (grounded in P or N)
B08 PSP SW (grn) PSP switch (power steering pressure??)
B09 STS (blu/wht) start signal
B10 VSS (orn) signal from VSS
B11 CYP P (orn) (shielded)
B12 CYP M (wht)
B13 TDC P (orn/blu) (shielded)
B14 TDC M (wht/blu)
B15 CKP P (blu/grn) (shielded)
B16 CKP M (blu/yel)
D01 VBU (wht/blu) battery via backup fuse
D02 BKSW (grn/wht) brake switch
D03 KS (red/blu) knock sensor (B18C1 only)
D04 SCS (brn/wht) service check connector
D06 VTP SW (blu/blk) VTEC pressure switch (B18C1 only)
(VTEC pressure switch ground G101 @ T-stat)
D07 TXD/RXD (lt blu) data link connector
D08 BARO OUT (lt grn) to TCM (auto trans only)
D09 ALT F (wht/red) alternator (charging rate signal)
D10 ELD (grn/red) electrical load detector (USA only)
D11 TPS (red/blk) throttle position signal
D13 ECT (red/wht) ECT sensor
D14 O2S (wht/red) signal from O2 sensor
D15 IAT (red/yel) IAT sensor
D16 VREF (wht/blk) to TCM (auto trans only)
D17 MAP PB (wht/yel) MAP sensor signal?
D19 VCC1 (yel/wht) power to MAP sensor?
D20 VCC2 (yel/blu) power to TP sensor?
D21 SG1 (grn/wht) signal ground?
D22 SG2 (grn/blu) signal ground (O2s?)
EDUALE
Feb 18, 2007 05:29 PM
Pondus
Nov 10, 2004 08:09 AM
AlphaQup
Sep 13, 2004 03:14 PM
ndogg
Sep 14, 2002 05:06 PM
