si cluster on an hf...need help
Old Dec 26, 2001 | 02:50 PM
shairacer's Avatar
Default si cluster on an hf...need help
i have an hf and i just bought an si cluster because the car was missing it....the plugs are all the same but nothing works....i read somewhere that it needs to be rewired...if anyone knows where i can find this information online or if you know how to rewire it please help....or anyone located in north cali who has an hf gauge cluster for sale let me know...i went to HAP and they are all out....btw my car is an 88 so only the 88-89 cluster will fit...thanks in advance
Old Dec 26, 2001 | 03:03 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: si cluster on an hf...need help (shairacer)
Weird. I put a 90 si cluster on my 90 HF and it works perfect.
Go to a local junk yard and get the plugs off the Si. cut the wires about
3 inches long. the wire colors are the same, just the location on the plug is different.
or, if you can remove the dash and swap the cluster wiring, you won't have to do any cutting.
Old Dec 26, 2001 | 05:02 PM
jdmhondageek's Avatar
Default Re: si cluster on an hf...need help (Spaceballs the lunch box)
if the cluster ever got wet from rain in the yard it probably won't work. i had that problem before i got my JDM.
Old Dec 26, 2001 | 08:49 PM
shairacer's Avatar
Default Re: si cluster on an hf...need help (Ayanami)
im pretty sure its not the cluster because when i plugged it in...the check engine light came on even though the ecu was not showing any codes...that was the only indication that the cluster was working...i also remember reading somewhere that si clusters wont work on an hf without rewiring....and the guy at the junkyard told me when i took it back that its true because the hf has a shift light...im gonna go back there and do what spaceballs said and buy the dash wiring....thanks guys
Old Dec 27, 2001 | 12:23 AM
crxgurlllll's Avatar
for clusters on crxs...
88 in an 88
89 in 89
90-91 in 90-91
Old Dec 27, 2001 | 12:58 AM
prsaumur-91ef-sihatch's Avatar
Default Re: si cluster on an hf...need help (eraser)
get a chiltons manual if you havent. I goes into detail what the differences are between the HF and SI. My dad has a '90 Hf and we put an Si cluster in that, just two wires from the distributor to the tach and that's all she needed. But I warn you to use caution when doing this as the chiltons manual is very hard to read if you aren't mechanically inclined. A haynes would be a better choice if you have very little knowledge about this and just want to get a rough idea on how to rewire the cluster. Oh yeah and you will need the male Si plug that plugs into the Si cluster.
Just my $.02 Good Luck..............
Old Dec 27, 2001 | 10:45 AM
sicivic's Avatar
I actually replaced my cluster in my 89 Civic Si when the factory one went bad. It turns out that from 88-91 there where two types of cluster. A Nippon Denso and a Nippon Seyka. It will say on the back of the cluster. Also on the front right below the speedometer in tiny letter, you will see a NS or ND for which model it is. If you put a Nippon Denso model in a car that had a Nippon Seyka, then it wouldn't work and vice versa. You have to put a Nippon Seyka into a car that originally had a NS. But most 88-91 Civic Si that I've seen are NS. Hope this helps.
Old Dec 27, 2001 | 04:57 PM
Sgt_Ox's Avatar
http://www.geocities.com/MotorCity/G...1/cluster.html
Cut and paste this is Eric Bauers cluster wiring info. Bryan
zcmotor
Aug 11, 2008 09:24 AM
hondadx
Apr 11, 2008 02:21 PM
Project_EF
12
Feb 11, 2005 07:19 AM
tyflip2
Jul 15, 2003 04:07 PM
