Manual ecu for jdm D15B SOHC NON VTEC honda civic
Old Nov 14, 2004 | 11:33 AM
sman21's Avatar
Default Manual ecu for jdm D15B SOHC NON VTEC honda civic
I recently converted my 1999 D15B SOHC NON VTEC JDM honda civic from a Multimatic to a manual, what is the best manual ecu that can be used?
Old Nov 14, 2004 | 01:03 PM
HumanResource's Avatar
Default Re: Manual ecu for jdm D15B SOHC NON VTEC honda civic (sman21)
So you have an EK with the JDM D15B NON VTEC???
Not sure but here in the states I believe the 5 spd ECu for the D16Y7's are P2K....
PLEASE share the ORIGINAL ECU code
thanks
Chris
Old Nov 14, 2004 | 03:59 PM
dr_latino999's Avatar
Default Re: Manual ecu for jdm D15B SOHC NON VTEC honda civic (HumanResource)
You would want to use the ECU available for that motor, but only in manual. That will be the best out of the box ECU to use, as I do not know your country of origin.
Old Nov 15, 2004 | 04:23 AM
sman21's Avatar
Default Re: Manual ecu for jdm D15B SOHC NON VTEC honda civic (dr_latino999)
I am in Jamaica, the car is from Japan, my first choice would be to use the manual version to my ecu, but if other ecu's are available that would increase my performance with a slight increase in fuel consumption I would be willing to give it a try.
CAR INFO.
Original ecu :37820-PCV-601 (cannot get info. on this ECU on the net)
Engine: D15B SOHC NON VTEC (Honda civic Ferio LEV)
converted from CVT to 5 speed S40 Gear box
Car also has two 4 wire O2 sensors
Old Nov 15, 2004 | 04:24 AM
sman21's Avatar
Cresendo
Oct 3, 2021 02:36 PM
accord2civic2prelude
Mar 30, 2009 05:47 PM
Kipper-Fish
Nov 25, 2008 09:43 AM
ZCVTEC-SOHC
Jan 10, 2007 11:39 AM
mugenracer
May 4, 2004 05:50 AM
