where would i check for a MAJOR vacume leak
Old Dec 26, 2001 | 02:23 PM
zerofourLS-T's Avatar
New User
Default where would i check for a MAJOR vacume leak
my vacume is reading 0. my idle is around 400rpm. then it dies. this makes me think there is a MAJOR leak somewhere. where should i look first? am i wrong. could a small leak cause this? like a bov line or wastegate line?
thanks very much in advance for anyhelp. : )
Old Dec 26, 2001 | 02:26 PM
dustin's Avatar
Default Re: where would i check for a MAJOR vacume leak (zerofourLS-T)
Nah, it is not a vacuum leak. You sure all cylinders are firing? Check your firing order.
Engine needs fuel, air, compression, and spark (all at the right time)
Dustin
ic89
Oct 18, 2006 08:24 AM
delguiner
May 17, 2004 08:28 AM
fe519
Nov 26, 2002 01:13 PM
