Removing Powder Coating.
Old Nov 14, 2004 | 10:56 AM
biotech0123's Avatar
Default Removing Powder Coating.
I have had some items powder coated in the past and want to remove the color.
Are there any chemicals that could strip powder coatings?
Old Nov 15, 2004 | 03:40 AM
TheShad0w's Avatar
Default Re: Removing Powder Coating. (Snowflake)
bump!
Old Nov 30, 2004 | 03:40 PM
jlacoy82's Avatar
71.192.16.183
Default Re: Removing Powder Coating. (TheShad0w)
Bump, I'd like to know as well! If I can save on having a shop strip my wheels I'd like to know!
Old Nov 30, 2004 | 05:46 PM
bellmy2007's Avatar
Default Re: Removing Powder Coating. (jlacoy82)
try some low odor aircraft remover. stuff burns like hell when it gets on ur skin, but it strips metal like a beast. you should be able to get it at a pep boys or something like it.
Old Dec 1, 2004 | 04:56 AM
PrettyLude's Avatar
autozone carries it also
Old Dec 1, 2004 | 07:16 AM
regamaster's Avatar
Default Re: Removing Powder Coating. (biotech0123)
The easiest way to get it off completely is to take it to a powder coating company and have it burned off.
Old Dec 1, 2004 | 08:38 AM
cjohnson_2's Avatar
Default Re: Removing Powder Coating. (regamaster)
sandblast it off.
Old Dec 1, 2004 | 10:21 AM
car_boy_16's Avatar
Default Re: Removing Powder Coating. (cjohnson_2)
You reverse the baking process of the power coating by freezing it, then it will turn into powder again and fall off, easiest way.
Old Dec 1, 2004 | 11:01 AM
Dan GSR's Avatar
Default Re: Removing Powder Coating. (car_boy_16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by car_boy_16 &raquo;</TD></TR><TR><TD CLASS="quote">You reverse the baking process of the power coating by freezing it, then it will turn into powder again and fall off, easiest way. </TD></TR></TABLE>
never heard that
I know my local place that does powder coating ,sandblasts powder coat off
you can't really use any chemicals like paint stripper
its not really painted on
Old Dec 1, 2004 | 11:43 AM
car_boy_16's Avatar
Default Re: Removing Powder Coating. (Dan GSR)
...probably because you never heard a jackass like me talk before I'm just foolin around.
Old Dec 3, 2004 | 06:37 PM
TRG-Coating's Avatar
Resident powder coater
If its steel, best thing to do is bring it to a media blasting company and have it burnt off than blasted off. If its aluminum have it chemically removed than blasted, or blasted with plastic media/walnut shell. You cant thermally process aluminum to burn powder off.
Photik
Jun 27, 2006 01:30 PM
mcgee*
Apr 18, 2006 12:41 PM
BJOnewiper
Oct 5, 2005 07:18 PM
kidkombo
Northwest (Sales)
13
Jun 15, 2005 07:20 AM
bigwig
Nov 25, 2003 05:43 PM
