Need Help: How to discounnect the clock?
Old Dec 26, 2001 | 02:17 PM
Sam's Avatar
Sam
Default Need Help: How to discounnect the clock?
The guy help me to install the CD player messed up the wiring & now my clock will stay on even the car is not in the ignition switch, which will eventually dry out my battery, anyone know how to disconnect the clock? Is there a fuse that I can pull out? Please help.
Old Dec 26, 2001 | 02:25 PM
Spade's Avatar
Default Re: Need Help: How to discounnect the clock? (Sam)
Cut the wires
Old Dec 26, 2001 | 02:26 PM
DR. ON POINT's Avatar
Banned
disconnect what he did and do it right
Old Dec 26, 2001 | 06:02 PM
jdmciviceg's Avatar
New User
unplug the clock
Old Dec 26, 2001 | 06:24 PM
Civic242's Avatar
Well there should be one wire connected to the battey for memory and clock functions. With out it all your radio station presets will be wiped out and your clock won't hold the time when you turn the key to off.
Trust me that clock in your CD could run for months before your battery feels it's effect.
Old Dec 27, 2001 | 11:46 AM
Sam's Avatar
Sam
Default Re: Need Help: How to discounnect the clock? (Civic242)
Thanks guy, what I want to do is to disconnet the OEM clock since it is "resetting" itself eveytime I starts the car and stay on even I pull out the car, but apparently, the clock on my CD player is fine.
WHo knows how to unplug the factory clock?
Old Dec 27, 2001 | 12:49 PM
1fastcx's Avatar
you need to pull out the clock then right behind that will be a plug to pull out the clock you need to use a set of pics to pry it out with out scratching you dash
homerbalooza
Audio / Security / Video
Aug 1, 2007 12:50 PM
crxgator
Mar 7, 2006 02:10 PM
92'si
Oct 14, 2005 01:51 AM
DrumminBoy
Dec 29, 2002 05:20 PM
blackDA
11
Jan 30, 2002 03:32 PM
