How IS THis Possible
Old Nov 14, 2004 | 10:25 AM
EDVxRICHARD's Avatar
Default How IS THis Possible
Look At This Picture The CTR pistons are 10:1 ratio and the type S is a 11:1 ratio.....if the CTR is higher shouldnt the ratio be higher?????.....if there si an explanation will you please educate me.........[IMG][/IMG]
Old Nov 14, 2004 | 10:34 AM
WrongWD's Avatar
Default Re: How IS THis Possible (Qb3rT)
first of all, there is no ratio. second of all, if the releifs dive much deeper, it is possible to have a higher dome but lower compression. and why are you comparing a pct to a type s, when they're a completely different bore, with a completely different wrist pin placement?
Old Nov 14, 2004 | 10:45 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qb3rT &raquo;</TD></TR><TR><TD CLASS="quote">Look At This Picture The CTR pistons are 10:1 ratio and the type S is a 11:1 ratio.....if the CTR is higher shouldnt the ratio be higher?????.....if there si an explanation will you please educate me.........[IMG][/IMG]</TD></TR></TABLE>
Bore and stroke of the engine is also an important part of what determines the compression ratio of the engine, along with head cc, gasket thickness, piston dome and piston to deck height.
Shorter stroke, smaller bore (CTR) will need a bigger piston dome to make compression than a longer stroke, bigger bore (Type-S)
Old Nov 14, 2004 | 10:52 AM
EVOLUTIONINNYC's Avatar
nice picture posting skills..
johnzm
566
Mar 19, 2013 05:13 AM
dayaftertomorrow
Jan 23, 2006 12:20 AM
ek9dc2
Oct 13, 2003 08:12 PM
duRritztiNy
35
May 16, 2003 10:36 PM
ITR111
Aug 31, 2001 02:19 PM
