ecu problems ?
Old Nov 14, 2004 | 05:11 AM
99lsvtecauto's Avatar
Default ecu problems ?
i have a lsvtec fully built but sometimes it stalls when i come off the belt way i have a p28 ecu here is the list of mods . i think i might be the ecu sometime the cel comes on but it goes out .
could it be the ecu i have p28 chipped 3 chips 2 threw cel on runs fine but the idle is rough. it sounds like it wants 2 turn off . if i give it gas it ok turned up fuel pressure same problems new engine has 401 miles of breaking 2 500 miles ne help
block
99b18b
ac blockguard
arp mainstuds
golden eagle blockgirdle
arp headstuds
ge oil adapter
acl bearings
itr oil pump
gsr gmb waterpump
balanced crank
shotpeened rods
p73aoo pistons
new oil pan gasket
flp baffled oil pan
obx pulleys
itr crank pulley
drivetrain
gsr tranny
ls 5th gear
itr lsd
act stge 3 6 puck ceramic
comp clutch 9.5 lb flywheel
flp clutch line
compression 11:9:1
head b16a2
rev valvetrain
rev flat valves
port matching on tb & manifold
blox hi lift cams
65 mm str tb
blox manifold
h22 vtec 310 injectors flowed/cleaned
190 fuel pump
new valve gasket
new headgasket
new orings
tuning
p28 with custom dynologged mapping thru speedymotorsports .com
ge cam gears
Modified by 99lsvtecauto at 4:45 PM 11/16/2004
99lsvtecauto
Dec 25, 2004 10:37 AM
99lsvtecauto
Nov 22, 2004 02:37 PM
99lsvtecauto
Nov 18, 2004 10:29 AM
99lsvtecauto
Nov 18, 2004 07:21 AM
