"Clunk" when i make a right turn
Old Nov 13, 2004 | 10:28 PM
dawalude's Avatar
Default "Clunk" when i make a right turn
hey guys,
whenever i make a right turn, i hear a loud "clunk" from under the car. it only makes this sound when i make a right turn. also, if i make a hard right turn, the steering wheel becomes unaligned as well as the "clunk." what could the problem be? i have stock suspension. i'm going to have the dealer check it out, but I just want an idea so that I can tell them exactly what it is, instead of trusting them to find it. it basically makes the sound whenever the steering wheel goes to the right, whether over a speed bump or a curb and etc. could it be the axles? would the dealer replace that for me under warranty? thanks for ur help
Old Nov 13, 2004 | 10:32 PM
MackDad's Avatar
Default Re: "Clunk" when i make a right turn (dawalude)
Probably your CV axles..If the outer joint is over stressed, it will wear out and make that noise...I have already gone through 3 Auto-zone re-manufactured axles in my H22 Accord, and they all have done the same thing, started clunking...
Old Nov 13, 2004 | 10:34 PM
dawalude's Avatar
Default Re: "Clunk" when i make a right turn (MackDad)
do you know if that is something covered under honda warranty? thanks for ur help btw
Old Nov 13, 2004 | 10:51 PM
PrettyLude's Avatar
i think that's like a normal wear and tear maintenance job
Old Nov 13, 2004 | 11:02 PM
dawalude's Avatar
Default Re: (PrettyLude)
if thats the case, do you think its the axles or the steering column? or both?
Old Nov 14, 2004 | 12:56 AM
BrokeLude's Avatar
Default Re: (dawalude)
Right axle shaft, nothing else.
Old Nov 14, 2004 | 01:24 AM
dawalude's Avatar
Default Re: (BrokeLude)
thanks for ur help everyone i'll have it checked out
Old Nov 14, 2004 | 03:54 AM
97lude's Avatar
i'm starting to have this problem also, however its coming from the left side of my car and only when i come to a complete stop and then go again. guessing its the CV axles...ehh just another problem with my car
Old Nov 14, 2004 | 11:05 AM
dawalude's Avatar
Default Re: "Clunk" when i make a right turn (97Lude)
i feel you bro...i'm at 68k miles right now and all of a sudden, all these problems are starting to come up
Old Nov 14, 2004 | 11:14 AM
LudeyKrus's Avatar
Crawl up under your car and check all the suspension parts and make sure all joints and bolts are tightened down tight.
If everything is nice and tight, it's more than likely your CV joints. Check the boots to see if you have some tears or rips on them.
egvera89
Transmission & Drivetrain
Jun 24, 2013 08:17 AM
92egkirt
Feb 9, 2012 05:49 PM
EK_B
Oct 9, 2011 05:21 PM
pr0phet
Oct 17, 2005 05:28 PM
AcCO12D95
Aug 28, 2003 07:45 AM
