jdm gsr cluster in usdm ls?
Old Nov 13, 2004 | 07:33 PM
dumpeDc2's Avatar
I'm a Jackass
Default jdm gsr cluster in usdm ls?
like it says and if it dont fit how can I make it fit??????????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????/
Old Nov 13, 2004 | 07:39 PM
iBear's Avatar
Default Re: jdm gsr cluster in usdm ls? (dumpeDc2)
Maybe someone who knows exactly will post but i'm sure it will fit. I think you may also need to switch the green film in the back of the cluster.
Old Nov 13, 2004 | 07:41 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: jdm gsr cluster in usdm ls? (EJellyfish1)
switch the green film? that is why I wanted so it match the rest of my lights
Old Nov 13, 2004 | 07:46 PM
iBear's Avatar
the film behind the cluster, not inside.
Old Nov 14, 2004 | 02:19 AM
BlueIntegraBoy's Avatar
Match your lights? It's not going to light up amber, you know? Yes it will fit.
Old Nov 14, 2004 | 01:50 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: jdm gsr cluster in usdm ls? (BlueIntegraBoy)
I thought it lights up green like my stock ls one? and what film do you have to change and why?
Old Nov 14, 2004 | 01:57 PM
vtakk eg's Avatar
no it fits and it lights up amber
Old Nov 14, 2004 | 04:13 PM
Default Re: jdm gsr cluster in usdm ls? (J-d-EM-Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-d-EM-Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">no it fits and it lights up amber</TD></TR></TABLE>
It'll light up the whitish green like your LS, but not amber since it's not an ITR cluster
Old Nov 14, 2004 | 05:33 PM
dumpeDc2's Avatar
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It'll light up the whitish green like your LS, but not amber since it's not an ITR cluster</TD></TR></TABLE>
ya thats what I thought I just wanted to make shure
Old Nov 14, 2004 | 08:14 PM
vtakk eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It'll light up the whitish green like your LS, but not amber since it's not an ITR cluster</TD></TR></TABLE>wtf how is that
Old Nov 14, 2004 | 10:21 PM
MaskedAP1's Avatar
u dont need to swap the green film..i just fixed my cluster's problem, i know what u should do!!
if u want everything works prefect, just swap all 4 gauges from thejdm gsr one to ur usdm ls one..thats the BEST way to do it..and if u want amber light, just get 3 194 amber blubs
Old Nov 14, 2004 | 10:59 PM
Default Re: jdm gsr cluster in usdm ls? (MaskedDC4)
Is that how you fixed your fuel gauge?
Old Nov 14, 2004 | 11:00 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Is that how you fixed your fuel gauge? </TD></TR></TABLE>
yes sir
Old Nov 14, 2004 | 11:12 PM
Right on
Old Nov 14, 2004 | 11:32 PM
dumpeDc2's Avatar
I'm a Jackass
are we talking abought the green film on the back side of the cluster?
Old Nov 14, 2004 | 11:35 PM
I guess what DC4 is trying to say is to swap the four gauges from the JDM housing into the USDM LS housing to make sure they work. But I believe swapping the green film from the back will work. Then again, I sold a JDM ITR cluster and the guy said it was plug and play.
Old Nov 16, 2004 | 09:47 AM
dumpeDc2's Avatar
I'm a Jackass
its alot of work to switch the gauges I dont know if im up for it. to bad i already bought the cluster
Old Nov 16, 2004 | 10:58 AM
It's not a lot of work. Remove clear plastic cover. Remove the the three screws that hold on the bezel in the back. Each gauge contains like 2-4 screws in the back. Unscrew those. Do it to the other cluster. Swap gauges, screw everything back in. Replace. Enjoy.
Old Nov 16, 2004 | 11:34 AM
dumpeDc2's Avatar
I'm a Jackass
well how do you set the needles? the only experince I have with the in side of a cluster is when I tryed to turn back the miles and ended up breaking a good gsr cluster. when you pull the needles out the thing spins then you got to spin it back the try to get it to sit on the correct reading. what other way is there to make it work?
Old Nov 16, 2004 | 11:51 AM
There's no need to take needles off to swap the gauge assemblies. When you unscrew the screws, the gauge assembly comes out as a whole (i.e. fuel, temp, speedo, tach).
Old Nov 16, 2004 | 03:55 PM
MaskedAP1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">There's no need to take needles off to swap the gauge assemblies. When you unscrew the screws, the gauge assembly comes out as a whole (i.e. fuel, temp, speedo, tach).</TD></TR></TABLE>
im roger that
Old Nov 17, 2004 | 08:22 PM
dumpeDc2's Avatar
I'm a Jackass
ok im gonna try that good looking thanks
Old Nov 17, 2004 | 08:32 PM
RaNMaN's Avatar
I put gsr gauges into my LS cluster (for higher rev's) and ended switching all the gauges to match right. It works great & looks frikkin awesome..
When we first tried just plugging in the gsr cluster and gauges, some of the other lights were not working correctly but that was because they were different OBD's I think. You might have to customize it a lil, no biggie.
btw, how many lbs are you boosting to get those numbers at the track? and do you have 1/8 mile times, i've only run the 1/8 in 8.9, and i'm running 10 lbs..
Old Nov 17, 2004 | 09:18 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: jdm gsr cluster in usdm ls? (RaNMaN)
when i went 13.4 I was at 8 psi, 60fts where around 2.1 on azines and I was hitting 8.8 in the 1/8 there.
Old Nov 17, 2004 | 09:37 PM
sir boostalot's Avatar
damn, i was about to get a usdm itr gauge cluster, hope i don't run into any problems (for 97 ls). and i definetely dont wanna mess with the needles.
