which mark is advance on the crank pulley, i forgot
From: not riding any bandwagons in, massachusetts, usa
advance is a direction, not a mark. tdc is the single white mark. engine spins counterclockwise. the further left (toward headlights) you see your flashes the more you are advancing. the red mark on d16's is 16degrees btdc. rotating your distributor toward firewall is advance.
Nextelbuddy
Mar 29, 2004 11:43 AM
