wierd noise *clutch*
Old Nov 13, 2004 | 05:09 PM
integra_si-vtec's Avatar
Default wierd noise *clutch*
ohk here is the problem
when i press the clutch all the way down and leave it in neutral everything is fine. and there is no noise...
but when i press the clutch all the way down and try to put it into any gear
it starts making a whinning noise and it wont go away unless i let go of the clutch completely...
i dont know what is making this noise and i tried to search everywhere..
can somebody please tell me what it is????????
Old Nov 13, 2004 | 05:14 PM
KeithsDAteg's Avatar
Default Re: wierd noise *clutch* (honda-tech'er)
I could be you input shaft bearing.
Old Nov 13, 2004 | 05:18 PM
well what could i do to fix this problem?? do i need to take it to the shop?? or should i just get a whole new OEM clutch?
Old Nov 13, 2004 | 05:44 PM
AlphaQup's Avatar
Default Re: (honda-tech'er)
Could be a worn throw-out berring (I think thats how you spell it) haha
If chances are that you haven't replace your clutch after 60K... It's probably a good time to change out for a whole new aftermarket setup. The package usually includes a new "throw-out berring". Good luck mang.
Old Nov 13, 2004 | 05:50 PM
Default Re: (AlphaQup)
If it is you r throw out bearing, then chances are you need a whole new clutch kit.
If it is you input shaft bearing, chances are you need a whole new clutch kit and you need you take your tranny somewhere and have them put in a Input shaft bearing in.
What you need to do, is pull your tranny and see for yourself.
good luck
Old Nov 13, 2004 | 07:53 PM
what clutch kit do u guys recomend?? i dont want anything too fancy.
Old Nov 13, 2004 | 08:14 PM
aznsins88's Avatar
I have a problem very similiar to that one, for me though, when i press the clutch all the way down, neutral or not, theres no rattling noise, but when i let off the clutch, theres a rattling noise and i was wondering wat it could be. I just got a new cltuch kit so i dont think it could be that, so anyone have any ideas?
Nick Kozeski
Sep 2, 2015 02:18 PM
Solstic
Jun 13, 2012 11:34 AM
jmr828
May 23, 2008 07:51 PM
levifps
Jun 25, 2007 12:16 AM
Beezle
Oct 2, 2004 10:25 AM
