axel on hub problem
Old Nov 13, 2004 | 04:39 PM
InTeGrA B18b1's Avatar
Default axel on hub problem
i can get the axel in the hub whent eh lower ball is in. I dont know what to do..
Old Nov 13, 2004 | 04:58 PM
boosted k20's Avatar
Default Re: axel on hub problem (InTeGrA B18b1)
well i dont know what to do either since i have no clue what u r talking about
Old Nov 13, 2004 | 05:34 PM
KeithsDAteg's Avatar
Default Re: axel on hub problem (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">i can get the axel in the hub whent eh lower ball is in. I dont know what to do..</TD></TR></TABLE>
Spell check works wonders.
But from what I can make form it, you were trying to say--I cant get the axel in the hub when the lower ball joint is in. I dont know what to do.
You need to seperate the lower ball joint. Then you axel should slide right out.
Old Nov 13, 2004 | 06:07 PM
Default Re: axel on hub problem (KeithsDAteg)
my hands were kind of black and sometimes people are in a hurry, you should know. well the when i bolt up the lower ball joint i dont have enough room to put my axel back in.
If i put my axel in first i can't get it line it up with the lower ball joint.
Old Nov 13, 2004 | 07:00 PM
bump ttt
Old Nov 13, 2004 | 11:07 PM
SSBPGSR's Avatar
is ur axel in the tranny all the way? if its not in all the way the hub wont line up with the ball joint. double check and make sure the axel is COMPLETELY in the tranny. then slide the axel into the hub and try again.
Old Nov 14, 2004 | 04:33 AM
Default Re: axel on hub problem (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">is ur axle in the tranny all the way? if its not in all the way the hub wont line up with the ball joint. double check and make sure the axle is COMPLETELY in the tranny. then slide the axle into the hub and try again.</TD></TR></TABLE>
He is correct.
Is this axle a new one??
If not then you probably didnt get the axle in the tranny all the way.
If so, and the axle is in the tranny all the way, then you probably have the wrong axle.
Old Nov 14, 2004 | 09:50 AM
can teh axel pop out of joint? the axel is too long
Old Nov 14, 2004 | 10:39 AM
SSBPGSR's Avatar
an axel cant pop out of joint from you trying to put it in. is it a used axel? the only thing i can think of is you might have the wrong axel. or you just arent pushing it in the tranny all the way, dont try to " push " it in the tranny. get some gloves and crab the part that goes into the hub, have a friend hold the break assembly or do what i do, and put it on ur knee and SLAM that axel into place. think of it this way..if you can just easily push the axel into place, how is it going to hold up when driven? and get a light and have a friend slide under the car to make sure the axel is all the way in. once it slides in you can feel it. unless its the wrong axel then thats all i can think of..good luck meng
Old Nov 14, 2004 | 12:40 PM
SSBPGSR's Avatar
also, is this the drivers or passenger side axel? if its the drivers side, make sure the three bolts that go though the half shaft are in, if you cant thread them in. then the axel isnt in all the way.
Old Nov 14, 2004 | 04:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">also, is this the drivers or passenger side axel? if its the drivers side, make sure the three bolts that go though the half shaft are in, if you cant thread them in. then the axel isnt in all the way. </TD></TR></TABLE>
that was the problem it was lose from the half shaft therefore it was too long.
I put it back in the half shaft then i think it popped out . Am i suppose to put it in the half shaft and twist or something?
When i reinstall the axel it was riding ok then until i started driving and it makes a loud noise and is bumpy, i think it fell out again you think im right?
Old Nov 14, 2004 | 05:38 PM
well thanks if you helped me out i appreciate it.
the vibration from my car was because MY lug NUTz WAS LOOSE
lol
90CivicDaily
Jun 4, 2008 04:39 PM
mikekc99
Jun 13, 2007 10:42 PM
C-REX 88
Sep 6, 2004 12:28 AM
IanCT
Jul 20, 2004 01:46 PM
STG3PWR
12
Jun 5, 2004 06:39 PM
