please help making noise when v-tech hits
99 gsr when my v-tech hits its not that loud and starts to make loud bogging noise on and off,like what its saposed to make when v-tech works properly,but going on and off,im thinking its something to do with air cuz i can hear it turning on at 5800 rpm but then makes bogging noise and noise repeats faster as rpm goes higher.the motor 99 gsr is in a el PLEEEASE HELP...
Try checking the filter on the Vtec solenoid, and make sure your oil level/pressure is good.
You will probably have to take the solenoid off to check, not quite sure.
when i can't hear my vtech very well, i usually adjust the volume on the side of the handset. those ringers are cheap
on a serious note, have you checked the oil pressure and level? a lot of people's vtec problems are rooted to oil.
nope ive checked v-tech silanoid,perfect comdition even put friends in to see if broke but still same thing and what volume on the hand set,what u talking about
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1pntsic »</TD></TR><TR><TD CLASS="quote">nope ive checked v-tech silanoid,perfect comdition even put friends in to see if broke but still same thing and what volume on the hand set,what u talking about
</TD></TR></TABLE> lol, hes just joking w/ you. "v-tecH" is the name of a company that makes phones. I think you are referring to "v-tec". You should check your oil level.
how old is your fuel filter, check your injectors;secondaries. are you burning oil at a fast rate? check the oil level over a period of time (that was stolen from the 5 ppl before me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moacsupreme »</TD></TR><TR><TD CLASS="quote">I would take it somewhere and have it looked at. Chances are if you can't spell it, you don't need to be going at it with any tools.</TD></TR></TABLE>
--Harsh, but the truth...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moacsupreme »</TD></TR><TR><TD CLASS="quote">I would take it somewhere and have it looked at. Chances are if you can't spell it, you don't need to be going at it with any tools.</TD></TR></TABLE> Checking oil doesn't require too much technical knowledge.
THC07
Aug 16, 2006 06:55 PM
