turbo or A3??
Old Nov 13, 2004 | 11:56 AM
whycanti33's Avatar
Default turbo A3 or purchase a stock A2??
which would would be better to do turbo my a3 or purchase an a2??? can someone please help me out and tell me the advantages and disadvantages of both???
Modified by whycanti33 at 1:10 PM 11/13/2004
Modified by whycanti33 at 1:11 PM 11/13/2004
Old Nov 13, 2004 | 12:34 PM
360's Avatar
360
Default Re: turbo A3 or purchase a stock A2?? (whycanti33)
Pros of A2:
- $3000 (insert the price you found here)
- 6-spd tranny
- reliability
- no turbo lag
Cons of A2:
- only 200whp after bolt-on's
- takes cams, IM, TB, k20a flash just to hit 220whp
- no clear upgrade path
Pros of A3 + turbo:
- 270-300whp without touching internals
- 5-spd tranny (positive because less grinds than the 6, and longer gears = slightly better traction than the 6)
- staged upgrades available
- f/i has much more potential than n/a
Cons of A3 + turbo
- reliability
- $4000 (depending on what stage, which kit, etc.)
- will need to upgrade clutch
Old Nov 14, 2004 | 09:46 AM
whycanti33's Avatar
Default Re: turbo A3 or purchase a stock A2?? (360)
what are some good turbo kits for the a3???
Old Nov 15, 2004 | 07:25 AM
Kal's Avatar
Kal
cybernation.
greddy.
revhard.
sfp.
Depends if you want to keep emissions or not -- cybernation is the only one, i believe, that will eliminate your cat.
Old Nov 15, 2004 | 11:37 AM
k-series's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 360 &raquo;</TD></TR><TR><TD CLASS="quote">
I agree with everything but this. The EP3 gears are REALLY short in 1st and 2nd. The base RSX gears are taller and better for boost IMO.
Steve
Old Nov 20, 2004 | 06:05 PM
ek9jdm's Avatar
Default Re: turbo A3 or purchase a stock A2?? (k-series)
A3
Old Nov 22, 2004 | 03:06 PM
Silver_EP3's Avatar
Turbo A3 stage one will typically get you 250+ whp depending on what kit you get. That not even touching the internals, turbo cat, etc.
stock a2 will give you a punch compared to the vtec in an a3 but if you drive a turbo and then get in a2 you'll be dissapointed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 360 &raquo;</TD></TR><TR><TD CLASS="quote">Cons of A3 + turbo
- reliability
- will need to upgrade clutch</TD></TR></TABLE>
Turbos are just as reliable as stock car as long and it is installed right. Actually, an N/A a2 with that same amount of power will cause more problems than a properly tuned turbo a3.
Old Nov 22, 2004 | 05:37 PM
02black_si's Avatar
Default Re: turbo A3 or purchase a stock A2?? (Silver_EP3)
i think it's all what you want. If you like na and the higher revs get the k20a2 but if you just love boost i'd try to get a k24 from a crv for about 1000 and then turbo that. You'll have much more low end tq
I'mEK
May 11, 2007 08:14 AM
