obd2 to obd1 idle problem, with code 14 iacv..
Old Nov 13, 2004 | 11:56 AM
JDM96SpecCTR's Avatar
Default obd2 to obd1 idle problem, with code 14 iacv..
like i said i got a 96 dx with a y8 manifold and i put in an obd1 p28, and im getting a horrible idle...i also get code 14 for the iacv, but with obd2 its fine and i get no code. when i unplug it on obd1 it makes no difference, and when i put my finger over the hole it idles fine.. but on obd2 everything is fine...
i have searched this already and i see that obd1 cars use the fitv which obd2 doesnt have. and someone said to bypass the fitv, but if u dont ahve one how are u gonna bypass it??? the person that had this same problem also wasnt getting a code
help im tryin to make it to the track tomorrow and this is the last ditch
Old Nov 13, 2004 | 04:27 PM
Default Re: obd2 to obd1 idle problem, with code 14 iacv.. (JDM96SpecCTR)
ttt
Old Nov 13, 2004 | 04:30 PM
86si's Avatar
the dx eacv is a 3 wire valve...did you convert it to a 2 wire eacv
Old Nov 13, 2004 | 05:12 PM
Default Re: obd2 to obd1 idle problem, with code 14 iacv.. (86si)
well im actually using an ex iacv because i got a y8 mani and tb
Old Nov 13, 2004 | 05:14 PM
86si's Avatar
yes,but is your wires converted correctly
Old Nov 13, 2004 | 05:49 PM
well probably not...what do i have to do???
Old Nov 14, 2004 | 07:24 AM
Catman316's Avatar
Here u go!!
this link will help u. https://honda-tech.com/zerothread?id=852762
Old Nov 14, 2004 | 05:42 PM
Default Re: obd2 to obd1 idle problem, with code 14 iacv.. (Catman316)
hey thanks that seemed to help me somewhat, but now i have a long lope from about 1500-3000 rpm but no check engine light.. the problem was in my obd2-1 harness....it had the wire there for the vtec or 2 wire iacv not mine, so i kinda used that link to pigure something out
im gonna try the iacv slide in uberdata to see if that helps
1.9 LS-V DB7
Dec 10, 2010 10:08 AM
hondaman156
Nov 14, 2006 03:55 AM
sikcrx80
May 21, 2006 01:56 PM
BlkSIvic
Apr 26, 2005 06:37 PM
pokemon
Aug 29, 2004 10:13 AM
