squeaky alt belt.
Old Nov 13, 2004 | 11:54 AM
HamiltonRex's Avatar
Default squeaky alt belt.
My alt belt squeeks sometimes when its cold out. Then when i hit around 3-4k its super loud and i can smell burning ruber like when im doing a brake stand (but not so much) but same smell.
Im thinking the belt is too tight, now much play should there be, or up and down movement?
Thanks.
Old Nov 13, 2004 | 12:02 PM
crxgator's Avatar
Default Re: squeaky alt belt. (HamiltonRex)
9-11 mm of play...
Old Nov 13, 2004 | 01:02 PM
speed_racer012's Avatar
Default Re: squeaky alt belt. (crxgator)
yeah fix that. for now you could probably just buy some belt lubricant thought but. Does it. does it ever flip over on ya?
Old Nov 13, 2004 | 01:48 PM
Default Re: squeaky alt belt. (speed_racer012)
Yeah i can flip it 180 degrees max.
The belt shows no signs of cracking or wear.
Can i use wheel bearing grease? Or clear dielectric grease as belt lube?
Old Nov 13, 2004 | 02:05 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
I think what speed_racer means is "belt dressing"
It is kind of a sticky substance and messy as hell..
I think any type of lubricant will just make it worse..
If it is slipping already,and you grease it up,it will probably slip more.
Old Nov 13, 2004 | 02:33 PM
RCautoworks's Avatar
Default Re: squeaky alt belt. (88DXCRX)
mmmm belt dressing sounds good. Back on topic, just tighten your alternator belt, don't by any of those lubricants.
Old Nov 13, 2004 | 03:28 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
nothing like the wrong way to fix a problem huh?
Old Nov 13, 2004 | 03:38 PM
Default Re: (mike_belben@yahoo.com)
so should i only beable to flip it 90deg?
Old Nov 13, 2004 | 03:49 PM
Default Re: (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">so should i only beable to flip it 90deg?</TD></TR></TABLE>
If you can flip it 90 degrees its to loose.
Old Nov 13, 2004 | 04:26 PM
Default Re: (90blackcrx)
nice.. i can flip it 180 deg so its way to loose (meanign just grabbing the belt and twisting it, not physcially turning it upside down on the pullys)
Old Nov 13, 2004 | 04:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">nice.. i can flip it 180 deg so its way to loose (meanign just grabbing the belt and twisting it, not physcially turning it upside down on the pullys)</TD></TR></TABLE>
Yeah thats a little to loose.
AudioFunk
Nov 7, 2013 06:36 PM
JasonST
Sep 6, 2013 10:02 AM
dizzogotvtec
May 13, 2006 01:49 PM
cr-x si
Mar 23, 2003 04:43 AM
J T*
14
Apr 5, 2002 06:21 PM
