Integra LS spline count difference?
Old Nov 13, 2004 | 11:53 AM
GetCaughtDead's Avatar
Default Integra LS spline count difference?
Can anybody tell me if all 90+ LS tranny's have the same number of splines on the input shaft?
Somebody told me they were different between 90-91 and 92-93(or later), but I was double checking on various sites, and it actually seems that they're the same.
Please help!
Old Nov 14, 2004 | 03:27 PM
Default Re: Integra LS spline count difference? (GetCaughtDead)
nobody in the integra forum knows?
I talked to both Advance and Autozone. Advance tells me they're the same part. Autozone tells me they're different.
Old Dec 20, 2005 | 07:40 PM
. M i c h a e l's Avatar
dotmichael to you
bump for answers, i need to know as well.
Old Dec 20, 2005 | 08:50 PM
purplegsr's Avatar
Default Re: Integra LS spline count difference? (. M i c h a e l)
the 90-91 are small spline, while the 92-93 are large spline (like the 94-01). So yes, they are different and Autozone is correct.
Here is a link, go down to arw321's post
http://www.g2ic.com/forums/sho...pline
Old Dec 20, 2005 | 09:51 PM
dotmichael to you
Default Re: Integra LS spline count difference? (purplegsr)
wtf is big and small spline?
Old Dec 20, 2005 | 10:03 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">wtf is big and small spline?</TD></TR></TABLE>
referring to the size of the spline on the input shaft.
Old Dec 21, 2005 | 07:44 AM
purplegsr's Avatar
Think of the splines as ridges on the input shaft, if it's small/thin spline, you can fit more around the input shaft. The larger splines are thicker, so there are fewer going around. I'll see if I can find a picture for you.
Old Dec 21, 2005 | 10:19 AM
projectTeG's Avatar
90-91 trannies(y1,a1,s1,j1) use the small splined clutches
92-01 all use the larger splined clutches
92-01 clutch are interchangable/.
Old Dec 21, 2005 | 02:11 PM
dotmichael to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
Think of the splines as ridges on the input shaft, if it's small/thin spline, you can fit more around the input shaft. The larger splines are thicker, so there are fewer going around. I'll see if I can find a picture for you.</TD></TR></TABLE>
yes please if you could.."smaller" and "larger" are relative.
unless i had an actual 90-91 or 92+ clutch...i wouldnt be able to know which is the "smaller" one
Old Dec 21, 2005 | 02:59 PM
purplegsr's Avatar
Ok, I couldn't find a picture to save my life. So to describe, the 92+ b-series transmissions have a larger diameter input shaft and they have 26 splines (I think the splines are also a little thicker than the 'small spline' ones, but I could be mistaken). The important thing is that the actual shaft and the count of splines is different.
The 90-91 b-series trannies (including ones that came with b16 motors) have a smaller diameter input shaft and 24 splines. The only thing this matters for is the clutch plate. If you try to put a 90-91 clutch plate on a 92+ tranny, it won't fit on because the input shaft is too thick. If you try to put a 92+ clutch plate on a 90-91 tranny, it will fit over because it's too big, so it should be really loose. As for the flywheel and pressure plate, they are reportedly interchangeable, it's just the clutch plate that will be different.
Hope that helps. I want to say the 24 spline input shaft is 26mm in diameter, and the 92+ would be a bit larger, but I can't remember where I got that information.
hondamn1320
Apr 5, 2008 10:26 AM
yz125rider21
13
Dec 21, 2006 02:12 AM
GetCaughtDead
Nov 14, 2004 08:41 PM
Mordeki
Oct 4, 2004 03:26 PM
civic_crazy
Jul 27, 2004 10:06 PM
