road racing...which mod would you do?
If you had several hundred dollars to spend on your R and were taking it to the track in the next few months would you:
A) lower it a little with nice springs (H&R or Comptech) on stock shocks
or
B) upgrade the pads/brake fluid with some stainless steel lines
Please help me choose!
Mike
or
Mike
I would buy an extra set of tires, if you don't allready have a set.
I lowered my R half an inch on stock shocks, I didn't help much really.
Oh, I forgot to mention I have Comptech springs....Don't waste your money.
It looks and handles stock, plus it throws the camber off a little.
Thanks for the quick responses guys. I also thought about the Mugen rear swar bar. I think i will get the pads/fluid from Mike at IPS since i have done business with him before. this will be my first track event. what pads/fluid do you reccomend? Thanks in advance!
Mike
Mike
Carbotech Panter Plus pads are really good IMHO. If you are on a budget use Valvoline Synthetic or Ford Heavy Duty brake fluid. Both are almost as good as Motul RBF600 or ATE Super Blue but are easier to find off the shelf and are cheaper. I'm running Carbotech pads up front, stock pads in the rear, and Motul fluid but will be switching to one of the cheaper fluids in the future. I'd also suggest pulling off you dust shields at the same time that you swap pads. The shields help retain alot of heat
who else has taken there break sheilds off?? there is no ill effect from doing this right?? why in the hell does honda keep putting chit on the car that i have to keep taking off!!
I personally have not heard of anybody frying their lower balljoint...but just passing on some info I read on king's site.
so if no one else knows they will be coming off this weekend along with performing a valve adjustment while i have nothing else to do.
i recommend option B w/o SS lines yet along with everyone else
. also, depending on the pads, maybe consider getting a set of rotors for track use as well.
Pads, Carbotech panther plus, you will love them and they are streetable...
Fluid, hard to beat ford HD... I use ATE superblue/type 200 because i can get it close by...
Splash sheilds, should have to worry about taking them off until you are quite experienced and running R compound tires.. Once you get that far, then take them off because you will be really building up some heat, and it needs to go away.. No balljoint problems with me and I haven't had them for 2 years, and a year of tracking.. If your worried about it, wrap you balljoint in some heat sheild/tape/alum. foil or whatever I guess...
[Modified by Honda318dx, 7:58 PM 12/26/2001]
me too. they were the next thing on my list to get. if everyone is talking chit about them, then i'm going to jump on the wagon and say fock them for now...
I'm curious why everybody seems to be saying not to get the SS brake lines...
BTW I have Panther + on my 00Si and they are SICK! Contact Andie @ Carbotech he is cool as hell.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
I'd suggest something more track only.. Hawk Blue's or Hawk Blue molded pads from carbotech. It takes very little time to change pads so I don't see any reason on earth to use a single pad for street and track.
The SS line thing was already explained.
Plus I have just heard too many stories of frayed, leaking, and otherwise broken SS lines. The brakes take a beating on track, less variables the better. At most tracks your brakes are the only thing keeping you from stuffing your car into walls, trees, burms, tires, etc.
