Tips on Axle Seal Replacement?
Old Nov 13, 2004 | 10:42 AM
B2FiNiTY's Avatar
Default Tips on Axle Seal Replacement?
I just got done replacing the passenger side axle and it is leaking tranny fluid. Seems to be coming from the axle seal even though when I inspected it, it looked totally fine.
Regardless, is there a way I can remove the axle from the tranny WITHOUT removing the axle from the hub?
For example, on Integras, I can just drop the LCA (lower control arm) and pull the axle out of the tranny since the hub has free play now. Is this possible on the crx?
Also, what do you guys recommend using to remove the axle seal and putting it back in? Use pliers to pull out the old and use a 32mm socket to press back the new?
Old Nov 13, 2004 | 11:47 AM
dcoultis's Avatar
i used a regular pry bar and a cloth to pop mine out, and lube up the seal with some grease before you put it in and push it as far as you can by hand then tap it in gently with a rubber mallet the rest of the way tell it is flush with the tranny case, dont push it in any farther then that or you risk damaging the seal
Old Nov 13, 2004 | 01:15 PM
ihateslowhondas's Avatar
seal driver
Old Nov 13, 2004 | 01:18 PM
B2FiNiTY's Avatar
Default Re: (ihateslowhondas)
What about removing the axle via the lower control arm? Is this possible?
Old Nov 13, 2004 | 01:32 PM
messeduprex's Avatar
Default Re: (B2FiNiTY)
i would undo the lower ball joint and the axle nut pop the axle out and your good it should only take 30 min to do both
Old Nov 13, 2004 | 04:14 PM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">What about removing the axle via the lower control arm? Is this possible? </TD></TR></TABLE>
Yes, of course.
Unlock the steering wheel
Remove the 2 bolts from the Radius Rod
Remove the Sway Bar Bushing(s)
Remove the Lower Control Arm to body Pivot Bolt
Turn the steering all the way (pushing the tie rod away from the car)
Pop out the inner joint!
Old Nov 14, 2004 | 10:30 AM
B2FiNiTY's Avatar
Default Re: (7PSI CRX)
It seems to be easier just to remove the lower ball joint.
Old Nov 14, 2004 | 11:08 AM
-16V-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It seems to be easier just to remove the lower ball joint. </TD></TR></TABLE>
Ditto
WPeters
Apr 30, 2008 07:19 AM
crx18c1
10
Apr 17, 2007 10:17 PM
Bird333
Jul 12, 2005 09:01 AM
homesauce
Mar 25, 2005 11:15 PM
See Are X
Oct 21, 2003 09:23 PM
