Drain plug for manual transmission.
Old Dec 26, 2001 | 09:22 AM
KF_S2000's Avatar
Default Drain plug for manual transmission.
If I remember correctly, the drain plug is a square allen type head. Does anyone know what size it is? I wanted to buy that particular socket without buying a whole set. Thanks.
Keith - Who's a cheap bastard.
Old Dec 26, 2001 | 09:24 AM
yoshi234's Avatar
I shoot brides
Default Re: Drain plug for manual transmission. (kf_Type-R)
no need for special t00z. just use 3/8" ratchet
Old Dec 26, 2001 | 09:33 AM
KF_S2000's Avatar
Default Re: Drain plug for manual transmission. (yoshi234)
Nice! So a 3/8 will fit right in there? That's good! Thanks for the reply.
Old Dec 26, 2001 | 09:37 AM
Spade's Avatar
no need for special tool. just use 3/8" ratchet
you will need either a 14mm or 17mm (cannot remember) wrench for the plug up top to fill the tranny + a bendable funnel.
Old Dec 26, 2001 | 09:50 AM
Lip's Avatar
Lip
Default Re: Drain plug for manual transmission. (Spade)
no need for the bendable funnel. remove the speed sensor from the top back of the tranny (1 10mm bolt) and pour your fluid in that hole instead. fill til the fluid just comes out the normal fill hole. its easier this way.
Old Dec 26, 2001 | 12:18 PM
B2FiNiTY's Avatar
Default Re: Drain plug for manual transmission. (Lip)
Wow. Never would have thought of something like that.
Old Dec 26, 2001 | 12:55 PM
Tommy_Gunns's Avatar
Lip, you got a pic of where this is at or a location description?
Old Dec 26, 2001 | 01:05 PM
RyanR's Avatar
Default Re: Drain plug for manual transmission. (Tommy_Gunns)
It's on the back top side of the transmission. Right next to the rear transmission mount bracket. There is a plug with 3 wires attached to it.
Peter_404_21
Dec 30, 2008 08:54 PM
tchen415
Jul 15, 2007 09:10 PM
ajwiant
Mar 4, 2006 08:33 PM
Matgallis
Nov 10, 2003 01:19 PM
4doorLX
Oct 2, 2002 10:55 AM
