compression 11:01 in gsr
Old Dec 26, 2001 | 09:07 AM
raifordmotors's Avatar
Default compression 11:01 in gsr
can you get 11:01 without boring the block ?what is the most you can get with out having to do this?
Old Dec 26, 2001 | 09:17 AM
fowler!'s Avatar
Default Re: compression 11:01 in gsr (raifordmotors)
yeah, all you do is put some ITR pistons JDM or USDM and you'll be fine. Put you right over 11:1
Old Dec 26, 2001 | 09:18 AM
6SPD_EK's Avatar
get stock bore size OEM JDM ITR pistons - should put you around 11.4:1 compression, you'll have to have the engine taken out and the cylinder walls honed - est. labor cost $600-$1000, the pistons you can get from Mike @IPS with rings (he had a special for $275 pistons, rings, & pins)
Old Dec 26, 2001 | 09:28 AM
ITC Racer's Avatar
Compression ratio has little to do with the cylinder bore size. The comp ratio is the ratio of the cylinder and combustion chamber with pistons at bottom dead center divided by same area with piston at top dead center.
To increase the comp ratio, you can mill the head the desired amount, get higher compression pistons of whatever bore you currently have, or have someone like DPR rework the combustion chambers to increase the comp ratio.
Old Dec 26, 2001 | 11:58 AM
wuhungsixxx's Avatar
New User
do u guys know approximately how much hp/tq gains with the new itr pistons?...just curious...
dc2_916
Sep 14, 2008 10:23 AM
123Four
Aug 14, 2007 07:01 AM
Si Integra
Feb 11, 2004 02:29 PM
done
Apr 29, 2002 06:04 AM
C-speed
Nov 12, 2001 05:52 PM
