Decisions Decisions
Old Nov 12, 2004 | 08:02 PM
PowerHouse's Avatar
Default Decisions Decisions
i've got my 84 mm pistons,rings, and pins in the garage.
i was curious if i should just buy a b20z shortblock or just bore out my b18c1 to 84 mm.
the heads going to be a gsr with itr valvesprings,retainers, and ctr cams.
compression for the pistons is rated at 11.8, forged.
other than that just basic bolt-ons...
recommendations?
Old Nov 13, 2004 | 12:42 AM
hybrid_vtec's Avatar
Default Re: Decisions Decisions (PowerHouse)
you have to sleeve it!
Old Nov 13, 2004 | 09:49 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Decisions Decisions (hybrid_vtec)
yes you have to sleeve the gsr block which is more$$$ OR YOU CAN JUST DROP THOSE PISTONS INTO THE B20 BLOCK
Old Nov 13, 2004 | 02:44 PM
PowerHouse's Avatar
i just came accross an ls block for 500. should i just buy that and sleeve it.(b20)?
Old Nov 13, 2004 | 04:41 PM
98itr0448's Avatar
no, you should tell who ever is trying to sell you an ls block for 500.00 to kiss your ***. I paid 200.00 for my ls block and crank! There are better deals out there. Unless you use the b20, you'll have to sleeve. That can cost anywhere from 700-1200.00 depending on who you send it to. I would run the b20 with a block guard. That should be fine as long as you dont run too much boost (if thats your intention). Good luck, search for a better deal on an ls block.
Old Nov 13, 2004 | 05:43 PM
PowerHouse's Avatar
thanks, i guess i'll go and seach for a b20 motor rather than bore it out. it sounds like a much cheaper, better idea.
Old Nov 16, 2004 | 04:04 PM
DYNO-PRO
Default Re: (PowerHouse)
Jdmefsir12
Jun 19, 2011 04:14 PM
Robs94gsr
Jan 12, 2010 05:04 PM
lakai_19
May 21, 2007 02:25 PM
THE GAME IS THICK
19
Sep 22, 2004 08:37 PM
Boostless97Lude
Nov 20, 2002 09:11 PM
