Fan Relay: where is it?
My radiator fan on my '89 Si doesn't turn on. I discovered this problem when I was getting my car smogged, when it was running without moving for quite a long time. I hooked up the fan to a battery and it ran just fine, and my car isn't overheating in normal driving, so the thermostat isn't stuck, so I figure it has to be a bad fan relay. The problem is, I can't find it in my engine bay! I followed the fan wire all the way back to the fusebox, and there aren't any relays in the path. Could someone please tell me where I can find it? Thanks.
If its not too much trouble, could you post page 23-86? It looks like that will contain instructions on testing the fan relay. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ToneDaBass »</TD></TR><TR><TD CLASS="quote">If its not too much trouble, could you post page 23-86? It looks like that will contain instructions on testing the fan relay. Thanks.</TD></TR></TABLE>
I can do better than that!
http://www.binghamtonlife.com/manual/2gsm/
