milling d15b head
Old Nov 12, 2004 | 06:44 PM
ihateslowhondas's Avatar
Default milling d15b head
i am going to get my head milled but i am curious on how far i can take it before it causes any problems, excluding timing issues. i will also be using the y8 metal head gasket and an ajustable cam gear. i belive timing is reatrted 1 deg. for every 12thousanths off the head, correct me if im wrong. what compression should i end up with , stock is 9.2:1
Old Nov 12, 2004 | 07:02 PM
also im curious if rods from a d16 will run in the d15 block, ive heard they are the same but i dont know for sure.
Old Nov 12, 2004 | 08:34 PM
sheissrx's Avatar
Default Re: (ihateslowhondas)
look in the service manual.
Old Nov 12, 2004 | 08:57 PM
CRXracer88's Avatar
Default Re: (sheissrx)
i think .030 is a safe limit . there are some valves out there for all motor set ups . there flat . that would help bump the compression . and take the center layer out of the y8 head gasket. oh yea .012 is 1 degree
Old Nov 12, 2004 | 10:16 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
try 1 degree advance per .012"
if youre gonna mill that much and/or remove gasket layers i surely hope you intend to clay the engine.
Old Nov 12, 2004 | 10:21 PM
CRXracer88's Avatar
Default Re: (mike_belben@yahoo.com)
there has been many others run this same setup with no prblems but claying the motor is still a smart thing to do . better to be safe than sorry.
Old Nov 13, 2004 | 01:54 AM
Nerologic's Avatar
.030 is a good slice to take off, u have to be carefull, that motor already has slightly higher comp then a d16, so a move more the .030 might make u detonate/knock on 91 octane...
Old Nov 13, 2004 | 09:18 AM
no i guaranteee it would not knock if i got it up to 10.5:1 because the ecu in it now makes it run incredibly rich and thats why i want to raise compression. i bet shaving of.030 wont make it above 9.8 with that gasket
Old Nov 13, 2004 | 09:20 AM
you need to retard the timing when you shae the head, it makes the timing advance when you take off.
Old Nov 13, 2004 | 09:51 AM
CRXracer88's Avatar
plus we have better than 91 octane gas here.
Old Nov 13, 2004 | 09:54 AM
Bserieskllr's Avatar
you advance the cam timing when you mill the head.....i milled my z6 head .040 and it put me just under 10.0:1 c/r, wish i knew about the zc pistons before i did it.
Old Nov 13, 2004 | 11:10 AM
honda engines rotate counter clockwise. when you mill the head, the slack in the belt lets the cam gears go clockwise (retard). the camshaft itself needs to be turned counterclockwise while the gear body remains stationary to correct. this is advance.
Old Nov 13, 2004 | 01:19 PM
oh my
GC106XT
Jun 17, 2014 03:09 PM
Red_ED8
Feb 23, 2008 09:13 AM
NACvicSi
10
Oct 19, 2005 01:31 PM
donnjuan2point2
Sep 16, 2003 10:08 AM
NateTEG95
Apr 27, 2003 05:41 PM
