Q?? high compression motors using oil
Old Nov 12, 2004 | 04:16 PM
ah789454's Avatar
Default Q?? high compression motors using oil
a friend of mine has a high comp b18 runing 13:1. and the car is spitting out blue smoke out the back when he decks it. he has done 4000km (i dont know what that is in miles ) and check the oil and its below half. is this normal?? cos i know a car aint suppose to use that much oil but i could be wrong. he says it cos its a high comp motor thats why its using all that oil
Old Nov 12, 2004 | 04:25 PM
Combustion Contraption's Avatar
high compression like 13:1 technically should not be burning any oil. So he basically burned 2 quarts in 4000 km? definately something to worry about....rings, valve seals, valves.... check everything.
Old Nov 14, 2004 | 03:03 PM
Jago's Avatar
Default Re: Q?? high compression motors using oil (ah789454)
somehing is really wrong here.
jonyi27
Apr 21, 2014 11:55 AM
eg:R
Jun 4, 2009 08:10 PM
IntegraType-R
Oct 15, 2007 02:28 PM
Bbasso
Sep 17, 2003 03:22 PM
