To: RLrye95 and any others with an LS.
Old Dec 26, 2001 | 06:09 AM
Spade's Avatar
Default To: RLrye95 and any others with an LS.
hey i have a question.. Whats that plug right on top of the crank pulley on
the 97 LS block.. it can't be the crank fluatauating sensor cuz that plug is
by the distributor right?? I'm not sure. Its going in a 95 si hatch.. One
more thing. Does the Carb ref check out what year the motor is when u try to
certify it because its a 97 motor converted to OBD1 IE change the
manifold,distributor and injectors. thanx.
I cannot answer your sensor question right now......I am sure someone else can.
And I will edit this post when I find out more information about the OBD1 changeover. In the meantime http://www.hybrid.honda-perf.org/casmog.html
[Modified by Spade, 7:11 AM 12/26/2001]
Old Dec 26, 2001 | 06:39 AM
Spade's Avatar
Default Re: To: RLrye95 and any others with an LS. (Spade)
http://www.arb.ca.gov/msprog/aftermkt/replace.htm
lmndc4
Jan 16, 2014 07:53 PM
civicdust
Dec 24, 2005 08:07 PM
