Starting my Manual swap...need advice
Old Nov 12, 2004 | 04:08 PM
ItalynStylion's Avatar
Default Starting my Manual swap...need advice
Ok, im going to bolt up a 4th get tranny to a 5th gen. I went to a junkyard and found these...
Ok, so i got a shifter assembly from a 5th gen and the shift linkage. I got these axles out of a 4th gen and that half shaft too. Is that the stuff that i need? Im just makin sure im headed in the right direction.
Old Nov 12, 2004 | 07:30 PM
JDM-BB6's Avatar
Default Re: Starting my Manual swap...need advice (ItalynStylion)
Your gonna need a clutch pedal, brake pedal since they sit diffrent than the auto. Also make sure u get a 5 speed ECU from the same year as ur car. 97-98 are compatible, 99-00-01 are compatible. When i did my swap i had a 97 ecu in a 99 and my car idled funny and stalled after getting gas..Also make sure u have clutch resovoir, hydrualic booster and necessary line from pedal to those parts..
Old Nov 12, 2004 | 07:33 PM
hOndafienD 04's Avatar
yeap....long way to goo still...also get a act stage 2 and lightweight flywheel while its out now....
Old Nov 12, 2004 | 07:50 PM
BrokeLude's Avatar
Don't forget to document what you spend to help the next guy thinking about it...
Old Nov 12, 2004 | 10:07 PM
Default Re: Starting my Manual swap...need advice (BrokeLude)
dont worry, ill document everything...
Old Nov 13, 2004 | 01:31 PM
Also, does the 5th gen shifter assembly and the 5th gen shift linkage work just the same with a 4th gen tranny? I really need some help with this...
Old Nov 13, 2004 | 01:45 PM
wingwly's Avatar
search please
i've made a complete list on everything you need to do the swap. I've made it easy for you.
https://honda-tech.com/zerothread?id=979967
Old Nov 13, 2004 | 02:32 PM
Default Re: Starting my Manual swap...need advice (wingwly)
holy **** that post kicks ***! Ive searched time and time again and never seen that post though
preludejayes
Feb 2, 2008 08:00 AM
Preferio
Sep 25, 2006 04:46 PM
Yuleluder
Nov 11, 2005 09:46 AM
iCe_2x
Apr 29, 2005 10:53 AM
